If I’ve went through the “Frame & Mosaic” wizard to get a sequence built, and after the first 1 or 2 shots I realised the framing isn’t quite what I expected, how can I get SGPro to redo the first 1 or 2 frames after reframing, and continue the rest of the sequence with the new framing?
Thanks!
You could simply reset the sequence (Sequence/Reset Sequence) which will clear the progress for all events. Or you could double click on the progress number for that event (ex. 1/20) and reset the number to 0. Or you could just simply add a frame to your event repeat number. Lots of ways to do what you’re asking.
