It looks like when the mount is parked that it disconnects from TheSky and no longer communicates with the ASCOM driver. This is problematic as we need to know when the mount is finished parking. I’m not sure why the driver disconnects the mount upon park, this is not standard behavior. I think you’re going to have to take this up with the ASCOM developer that wrote this driver.
[6/4/2014 9:38:21 AM] [DEBUG] [Telescope Thread] ASCOM Telescope: Park message received.
[6/4/2014 9:38:21 AM] [DEBUG] [Telescope Thread] ASCOM Telescope: Dome slave set to park mount first, parking mount.
[6/4/2014 9:38:21 AM] [DEBUG] [Sequence Thread] Moving filter wheel, isMoving, check 2…
[6/4/2014 9:38:38 AM] [DEBUG] [Sequence Thread] Moving filter wheel, isMoving, check 2 complete…
[6/4/2014 9:38:38 AM] [DEBUG] [Sequence Thread] Checking for auto manual focus (pre)…
[6/4/2014 9:38:38 AM] [DEBUG] [Sequence Thread] Finished sending frame capture. Entering wait mode…
[6/4/2014 9:38:38 AM] [DEBUG] [Camera Thread] SGM_CAMERA_CAPTURE message received…
[6/4/2014 9:38:38 AM] [DEBUG] [Camera Thread] SBIG Camera: CaptureImage…
[6/4/2014 9:38:38 AM] [DEBUG] [Camera Thread] SBIG Camera: Start exposure…
[6/4/2014 9:38:38 AM] [DEBUG] [Camera Thread] SBIG Camera: exposure time = 3000
[6/4/2014 9:38:38 AM] [DEBUG] [Camera Thread] SBIG Camera: shutter is closed…
[6/4/2014 9:38:38 AM] [DEBUG] [Camera Thread] SBIG Camera: capture command sent…
[6/4/2014 9:38:40 AM] [DEBUG] [CP Update Thread] ASCOM Telescope: Error in IsSlewing : Not connected to TheSky. (System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. —> System.Runtime.InteropServices.COMException: Not connected to TheSky.
— End of inner exception stack trace —
at System.Type.InvokeMember(String name, BindingFlags invokeAttr, Binder binder, Object target, Object[] args, CultureInfo culture)
at ASCOM.DriverAccess.MemberFactory.CallMember(Int32 memberCode, String memberName, Type[] parameterTypes, Object[] parms) in c:\ASCOM Build\Export\ASCOM.DriverAccess\MemberFactory.cs:line 243)
at ASCOM.DriverAccess.MemberFactory.CallMember(Int32 memberCode, String memberName, Type[] parameterTypes, Object[] parms) in c:\ASCOM Build\Export\ASCOM.DriverAccess\MemberFactory.cs:line 284
at ASCOM.DriverAccess.Telescope.get_Slewing() in c:\ASCOM Build\Export\ASCOM.DriverAccess\Telescope.cs:line 1104
at a3.IsSlewing()
