In version 3.0.3.140, there is a problem with the rotator setting at the bottom of the target settings dialog box. There is an option to have the rotation setting locked to a given value (“Always”) and one that allows the rotation value to vary by +/-180 degrees. I use a manual rotator. In past versions, I used +/-180 because it allowed a meridian flip without user intervention.
Now, however, when I select the +/-180 option, it does not stay selected and the drop down menu becomes blank. The result is that the Always option is applied, even though the menu is blank. This bug interrupted a meridian flip last night.
This screen shot shows the +/-180 option selected:
When I close the target settings dialog box and subsently re-open it, the +/-180 option does not remain selected:
And, as I said above, the target “acts” like the Always option has been selected.
Anyone else having this problem?
Glenn
