If I need to re-start a sequence or a new sequence requiring re-connecting an STF-8300M camera, it won’t connect ( camera not found, etc), unless I disconnect the - already connected- Sti camera from PHD first.
Not a problem since I know the workaround already, just wondering if I have an incorrect setting…thanks.
I have a similar, and perhaps same issue: If SGP running my STT-8300M crashes for any reason, when I restart SGP I cannot connect to the STT-8300M. The sequence that works for me is to power down the STT-8300M, then power it back up. Now I connect just fine. For me has nothing to do with PHD2. Definitely not a problem for me.
Hm, I’ll have to look at this. It’s likely getting into a weird state as PHD is probably asking something of the guider and it’s not connected in SGP. I’m surprised it’s not causing PHD to fail to be honest.
This does not apply in my case. Perhaps for @4everNewbie. I only have 1 SBIG, but 2 Canon 6D’s, but I only run one of them at a time since with both powered on I can’t access either one of them.
OK, Thx. In that case I would say that the universal driver is just in a bad state and we might need to look at how we clean up during certain error conditions.
