The SGP API Guider is required for the SBIG dual-chip cameras. Since you have a separate guide camera you don’t need to go through the SGP API Guider interface. You can select SBIG Camera in PHD2 and you are good to go.
How do I let PHD2 know which SBIG camera to use? The ST 8300M is assigned to the main SGPro camera and at that time, I do get a dialog that asks me to choose between ST8300M and STi.
Hello Shailesh, I have the same issue with my STF8300C and Sti camera and getting same results as you. I asked the question to the forum 29 days ago with no response. I think the problem is with how SBIG configures their cameras. I go through gymnastics connecting both cameras up when I use Images Plus camera control and PHD2. I am waiting for a friend to let me borrow his Starlight guider and feel by having a different brand the issue will go away. I am a beginner with SGP also. Al Johnson
Thanks Shailesh, just read your other post and replies. We are not alone in dealing with this issue. As with you I considered forgetting about using SGP. Al J
