Hi folks,
Sequence Generator Pro 2.3.7 is released.
Changes / Fixes:
- Support for wide filed solves with Elbrus (you must re-install Elbrus
with the new installer for this feature to work) - Fixed a bug where loading mosaic cache images would load with the Y axis flipped
- SBIG camera IP addresses can now be entered manually
- Possible fixes for compatibility with Lakeside focusers
- Adding subframe support to the API
