Sequence Generator 3.1.0.413 (Stable) is Released for General Use
Hello! Thanks for keeping SGPro up to date. This release on the stable branch is free of charge to owners of SGPro 3. The list below contains a brief description of all feature additions, changes and fixes in this version.
You can find it here:
Changes
- Very large sequences will no longer background load targets and, instead, load targets on-demand.
Fixes
- A issue where some logs might not be visible in the Log File Browser.
- An issue that caused target start and end times to act nuts.
- Report a problem should work on all versions of Windows now.
- Save Sequence as Profile will no longer omit the source profile from the profile list.
- User aborting a centering routine during a sequence will still abort the sequence, but will not run end of sequence options.
