Hi folks,
Here is the latest 2.4.3 beta:
This will likely be the last release in the 2.4 line and will finish the implementation of these features:
http://forum.mainsequencesoftware.com/c/sequence-generator/2-4-x-features
2.4.3.2 Changes:
- Stabilized communication between SGPro and PHD2 (for profile management). Not perfect yet, but way better than 2.4.3.1. This beta requires the use of PHD2 2.5.0dev3. If you are not comfortable with using PHD2 dev builds, you might want to stick with the SGPro 2.4.2 release. You can find it here: http://openphdguiding.org/development-snapshots/
- Fixed a bug that could cause the dome to move in the wrong direction when imaging targets near the pole.
- Known Issue: If you open PHD2 by clicking its “settings” button on the control panel, do not close this instance of PHD2 prior to starting your sequence. SGPro will get confused about which version of PHD2 it is supposed to talk to and error out. This will be fixed in the next beta.
2.4.3.1 Changes:
2.4.3.0 Changes:
