Sequence Generator Pro 4.1.0.696 (BETA) (32-bit and 64-bit) is Released for Test
You can find it here:
First, go here => https://www.sequencegeneratorpro.com/downloads/
then click on the “Betas” tab and choose either 32 or 64 bit.
Sequence Generator 4.1.0.696
New
- Themes! Choose from light, dark, black and system themes (with or without gradients).
- New target tooltips. Hover over a target and see a bunch of stuff that you used to have to dig into target settings for.
- New target info icons. Below the name of every targets, see, at-a-glance icons indicating the slew, center, rotate and start times.
- A new, long target list. If you use sequences with, many, many targets, it can be frustrating to only see 6 at a time. Now, you can opt to move the target list to the far left and have it occupy the height of the sequencing window.
- Many, many small visual enhancements for a better user experience.
- Sequence background loading is faster and is now easier to interrupt if you’d like to use your computers power for other things.
- Many misc. things are faster… add and delete targets, add and delete target events and more.
- Better (and themed) folder picker dialog.
- Better color picker dialogs.
- More intuitive UI controls for entering time of day.
- SGPro startup is now faster (by about 20%).
- Slightly larger toolbar icons.
- New icons for connected disconnected gear and a clear green or red border that helps to indicate state.
- New, more structured layout for grouped controls.
- Moving between two very large sequences (with many targets) is now MUCH faster.
Changes
- Only show Beta warning for Betas
Fixes
- SGPro version update checker is no longer broken (because it now understands the the existence of 32/64 bit builds).
- Fixed a bug where SGPro would not stop Windows from going to sleep while a sequence was running.
- Adding a new target now forces that target to be visible in the target list.
- Fixed many, many misc small bugs and visual defects.
- Addressing issue where SBIG PreFlash could not be disabled.
- Stop attempting to connect to old Switch Sim.
