Sequence Generator Pro 4.2.0.955 (32-bit and 64-bit) is Released for
You can find it here:
Sequence Generator 4.2.0.955
Additions
- Added new option to add a delay between switch device connect and auto connect for other gear. Use custom var post_switch_device_connect_delay_sec
Fixes
- Changing ‘Connect All’ behavior such that already connected devices don’t attempt to reconnect.
- Changing the Sequence Summary menu item text to match other areas.
- Fixed an issue where a required Switch Device may not connect before the sequence starts.
- Fixed an issue where Capture Cal Frames even after Sequence failure may not be honored.
- Fixed an issue where some types of Observatory errors might be suppressed (fail silently without user warning)
- Preventing F5 to resume/start sequence when the Main Form is not accessible (ie a Modal is open)
