Downloaded SGP 2.4.2.4,
one cannot select the D810A in the list so I used auto connect …
Both my D600 and D810A error out with auto connect, claiming DLL is missing;
MSVCP110.dll is missing
I installed the framework from MS site, still same error …
The D600 works when I select it directly from the list, but I cannot select the D810A (D810 does not work either)
Not much in the log file, here the corresponding lines and then a quit;
[7/29/2015 9:18:15 PM] [DEBUG] [Sequence Thread] Entering sequence message dispatch loop…
[7/29/2015 9:18:15 PM] [DEBUG] [Main Thread] No change in telescope object…
[7/29/2015 9:18:15 PM] [DEBUG] [Main Thread] New rotator object (No Rotator) dispatched…
[7/29/2015 9:18:15 PM] [DEBUG] [Main Thread] New dome object (No Observatory) dispatched…
[7/29/2015 9:18:15 PM] [DEBUG] [Main Thread] New flat box object (No Flat Box) dispatched…
[7/29/2015 9:18:15 PM] [DEBUG] [Main Thread] New weather station object (No Safety Monitor) dispatched…
[7/29/2015 9:18:15 PM] [DEBUG] [Main Thread] New auto guider object (No Auto Guider) dispatched…
[7/29/2015 9:18:15 PM] [DEBUG] [Main Thread] No change in plate solver object…
[7/29/2015 9:18:15 PM] [DEBUG] [Main Thread] Checking if version check is required…
[7/29/2015 9:18:15 PM] [DEBUG] [Cleaner Thread] Running cleanup…
[7/29/2015 9:18:15 PM] [DEBUG] [Main Thread] UI layout found, loading layout at C:\Users\Yves\AppData\Local\SequenceGenerator\sg_ui_config.xml
[7/29/2015 9:18:15 PM] [DEBUG] [Cleaner Thread] Cleaning 0 files in directory C:\Users\Yves\AppData\Local\SequenceGenerator\Temp…
[7/29/2015 9:18:15 PM] [DEBUG] [Cleaner Thread] Cleaning multi camera registration file…
[7/29/2015 9:18:15 PM] [DEBUG] [Cleaner Thread] Cleaning finished…
[7/29/2015 9:20:25 PM] [DEBUG] [Main Thread] Connecting camera in camera thread…
[7/29/2015 9:20:25 PM] [DEBUG] [Camera Thread] SGM_CAMERA_CONNECT message received…
[7/29/2015 9:20:25 PM] [DEBUG] [Camera Thread] Nikon - Loading MD3 files from C:\Program Files (x86)\Sequence Generator\NikonLibs
[7/29/2015 9:20:25 PM] [DEBUG] [Camera Thread] Nikon - Loading C:\Program Files (x86)\Sequence Generator\NikonLibs\Type0001\Type0001.md3
[7/29/2015 9:20:25 PM] [DEBUG] [Camera Thread] Nikon - Loading C:\Program Files (x86)\Sequence Generator\NikonLibs\Type0002\Type0002.md3
[7/29/2015 9:20:25 PM] [DEBUG] [Camera Thread] Nikon - Loading C:\Program Files (x86)\Sequence Generator\NikonLibs\Type0003\Type0003.md3
[7/29/2015 9:20:25 PM] [DEBUG] [Camera Thread] Nikon - Loading C:\Program Files (x86)\Sequence Generator\NikonLibs\Type0004\Type0004.md3
[7/29/2015 9:20:25 PM] [DEBUG] [Camera Thread] Nikon - Loading C:\Program Files (x86)\Sequence Generator\NikonLibs\Type0005\Type0005.md3
[7/29/2015 9:20:25 PM] [DEBUG] [Camera Thread] Nikon - Loading C:\Program Files (x86)\Sequence Generator\NikonLibs\Type0006\Type0006.md3
[7/29/2015 9:20:25 PM] [DEBUG] [Camera Thread] Nikon - Loading C:\Program Files (x86)\Sequence Generator\NikonLibs\Type0007\Type0007.md3
[7/29/2015 9:20:25 PM] [DEBUG] [Camera Thread] Nikon - Loading C:\Program Files (x86)\Sequence Generator\NikonLibs\Type0008\Type0008.md3
[7/29/2015 9:20:25 PM] [DEBUG] [Camera Thread] Nikon - Loading C:\Program Files (x86)\Sequence Generator\NikonLibs\Type0009\Type0009.md3
[7/29/2015 9:20:25 PM] [DEBUG] [Camera Thread] Nikon - Loading C:\Program Files (x86)\Sequence Generator\NikonLibs\Type0010\Type0010.md3
[7/29/2015 9:20:25 PM] [DEBUG] [Camera Thread] Nikon - Loading C:\Program Files (x86)\Sequence Generator\NikonLibs\Type0011\Type0011.md3
[7/29/2015 9:20:25 PM] [DEBUG] [Camera Thread] Nikon - Loading C:\Program Files (x86)\Sequence Generator\NikonLibs\Type0012\Type0012.md3
[7/29/2015 9:20:25 PM] [DEBUG] [Camera Thread] Nikon - Loading C:\Program Files (x86)\Sequence Generator\NikonLibs\Type0013\Type0013.md3
[7/29/2015 9:20:25 PM] [DEBUG] [Camera Thread] Nikon - Loading C:\Program Files (x86)\Sequence Generator\NikonLibs\Type0014\Type0014.md3
