SGP only shows most recent image
SGP only shows the most recent image captured.
When I first started using SGP, each new image appeared in its own tab. So it was easy to flip back and forth between them. I probably did something, and now there is only one image tab, showing the latest image.
I did find a setting that seemed related, but it didn’t help.
If you open the View Options module the option is there. We typically recommend leaving it disabled as lots of images can cause stability issues with memory usage.
