Last night was very frustrating. I’ve had to start my sequence after each event as SGP kept ending the sequence an parking the mount. I’ve reset progress unchecked completed events and I still cannot determine why this is happening. The version is 3.0.3.140 and I’m using a G11 mount with a QSI camera.
Going through the log, I found that in some cases, but not all, there was a problem with PHD2 dither or settling. Dither was not on and I was getting ~0.3 pixels RMS guiding. Also, the log said recovery mode was not on.
In addition, SGP thought that it was time for a meridian flip 2 hours before it should have happened. Again, I have no idea why. Below is a log extract. The flip time was about 2.5 hours before NGC891 reached meridian.
This was a sequence I started more than a month ago and wanted to add more captures to each event. However, the prior sequence used the prior version of software.
I will start the RGB from scratch tonight an hopefully, with the latest PHD dev release, see better results.
Any ideas and suggestions for further changes are welcome.
11/10/18 22:09:33.333][DEBUG] [Sequence Thread] ------------- Starting capture frame for event[2] -------------
[11/10/18 22:09:33.339][DEBUG] [Sequence Thread] Sending commands…
[11/10/18 22:09:33.339][DEBUG] [Sequence Thread] SetFlatBox: Frame Type is Light
[11/10/18 22:09:33.339][DEBUG] [Sequence Thread] EventMarker 2 - t:ngc 891 and ACO347 (0); e:2; f:0; o:
[11/10/18 22:09:33.339][DEBUG] [Sequence Thread] Checking if Meridian Flip is needed
[11/10/18 22:09:33.343][DEBUG] [Sequence Thread] Telescope is on the West side of the mount
[11/10/18 22:09:33.343][DEBUG] [Sequence Thread] Meridian Flip needed, Hour Angle >= Degrees Past To Flip: 90.05427 >= 3.75
[11/10/18 22:09:33.344][DEBUG] [Sequence Thread] Running blocking meridian flip…
[11/10/18 22:09:33.443][DEBUG] [Pier Flip Thread] Meridian Flip: Starting Meridian Flip Procedure
[11/10/18 22:09:33.444][DEBUG] [Pier Flip Thread] Meridian Flip: Calling SGM_TELESCOPE_SOLVE - No Sync
[11/10/18 22:09:33.527][DEBUG] [Pier Flip Thread] Meridian flip: Waiting for scope solve to complete…
[11/10/18 22:09:33.529][DEBUG] [Telescope Thread] SGM_TELESCOPE_SOLVE message received…
[11/10/18 22:09:33.529][DEBUG] [Telescope Thread] Telescope solve with plate solver PlateSolve2…
[11/10/18 22:09:33.530][DEBUG] [Telescope Thread] Setting filter for scope sync…
[11/10/18 22:09:33.530][DEBUG] [Telescope Thread] Setting filter position 1…
[11/10/18 22:09:33.535][DEBUG] [Telescope Thread] Setting filter: Clear…
[11/10/18 22:09:33.535][DEBUG] [Telescope Thread] Moving filter wheel, isMoving, check 1…
[11/10/18 22:09:33.535][DEBUG] [Telescope Thread] Moving filter wheel, isMoving, check 1 is complete…
[11/10/18 22:09:35.281][DEBUG] [Telescope Thread] Adjust focuser pos per filter: Moving focsuer to focus position (8878)…
[11/10/18 22:09:35.308][DEBUG] [Telescope Thread] Adjust focuser pos per filter
[11/10/18 22:09:35.308][DEBUG] [Telescope Thread] Old filter: Red; Focus pos: 8878
[11/10/18 22:09:35.308][DEBUG] [Telescope Thread] New filter: Clear; Focus pos: 8878
[11/10/18 22:09:35.308][DEBUG] [Telescope Thread] Pos delta: 0 steps
[11/10/18 22:09:35.308][DEBUG] [Telescope Thread] New position-> (current: 4366) + (delta: 0) = 4366
[11/10/18 22:09:35.308][DEBUG] [Telescope Thread] Focuser moving to 4366
[11/10/18 22:09:35.335][DEBUG] [Telescope Thread] Focuser move call complete
[11/10/18 22:09:35.361][DEBUG] [Telescope Thread] Focuser position matches requested position (4366), continuing…
[11/10/18 22:09:35.361][DEBUG] [Telescope Thread] focuser move is complete…
[11/10/18 22:09:35.366][DEBUG] [Telescope Thread] Moving filter wheel, isMoving, check 2…
[11/10/18 22:09:36.366][DEBUG] [Telescope Thread] Moving filter wheel, isMoving, check 2 complete…
[11/10/18 22:09:47.396][DEBUG] [Telescope Thread] Plate solving scope frame…
[11/10/18 22:09:47.396][DEBUG] [Telescope Thread] Created full file name: C:\Users\Charlie Bradshaw\AppData\Local\SequenceGenerator\Temp\plate_solve_image-1.fit
[11/10/18 22:09:47.403][DEBUG] [Camera Thread] SGM_CAMERA_PLATE_SOLVER_CAPTURE message received…
[11/10/18 22:09:47.404][DEBUG] [Camera Thread] Collecting FITs headers for plate solve frame…
[11/10/18 22:09:47.488][DEBUG] [Camera Thread] ASCOM (QSI) Camera: setting gain to HIGH…
[11/10/18 22:09:47.488][DEBUG] [Camera Thread] ASCOM (QSI) camera: setting normal speed readout…
[11/10/18 22:09:59.981][DEBUG] [PHD2 Listener Thread] PHD2 - No messages received from PHD2 for 1 minute, checking socket with status…
[11/10/18 22:09:59.981][DEBUG] [PHD2 Listener Thread] Checking PHD2 state…
[11/10/18 22:09:59.981][DEBUG] [PHD2 Listener Thread] PHD2 GetPhdStatus - Pre-Wait : Stopped
[11/10/18 22:09:59.981][DEBUG] [PHD2 Listener Thread] Sending to PHD2:
{“method”: “get_app_state”, “id”: 1001}
[11/10/18 18:46:27.845][DEBUG] [Sequence Thread] PHD2 GetPhdStatus - Post-Wait: LostLock
[11/10/18 18:46:27.845][DEBUG] [Sequence Thread] Request to settle auto guider has failed. Guider reports it is not guiding…
[11/10/18 18:46:27.900][DEBUG] [Sequence Thread] Something has gone wrong while attempting to dither or settle the auto guider, but recovery mode is NOT active!
[11/10/18 18:46:27.900][DEBUG] [Sequence Thread] Adding sequence level notification: Something has gone wrong while attempting to dither or settle the auto guider, but recovery mode is NOT active!
[11/10/18 18:46:27.901][DEBUG] [Sequence Thread] Sending Notification: Error - Something has gone wrong while attempting to dither or settle the auto guider, but recovery mode is NOT active!
[11/10/18 18:46:27.901][DEBUG] [Sequence Thread] Recovery mode failed, aborting…
[11/10/18 18:46:27.913][DEBUG] [Sequence Thread] Run event requested sequence abort…
[11/10/18 18:46:27.913][DEBUG] [Sequence Thread] ********* Run post sequence *********
[11/10/18 18:46:27.913][DEBUG] [Sequence Thread] SGPro capture cal frame mode is OFF…
[11/10/18 18:46:27.913][DEBUG] [Sequence Thread] Clearing timed monitoring events…
[11/10/18 18:46:27.913][DEBUG] [Sequence Thread] Checking RunEndOfSequenceEquipmentOptions, force = True
[11/10/18 18:46:27.913][DEBUG] [Sequence Thread] In RunEndOfSequenceEquipmentOptions
[11/10/18 18:46:37.389][DEBUG] [Sequence Thread] User prevented end of sequence actions from running.
[11/10/18 18:46:37.399][DEBUG] [Main Thread] Aborting sequence timer thread…
[11/10/18 18:46:37.399][DEBUG] [Main Thread] Sending sequence end notification…
[11/10/18 18:46:37.399][DEBUG] [Main Thread] Resetting UI elements…
[11/10/18 18:46:37.399][DEBUG] [Main Thread] Checking if sequence has work left…
[11/10/18 18:46:37.400][DEBUG] [Main Thread] Work left…
[11/10/18 18:46:37.402][DEBUG] [Main Thread] Updating big status…
[11/10/18 18:46:37.402][DEBUG] [Main Thread] Enabling menu items…
[11/10/18 18:46:37.476][DEBUG] [Main Thread] Set target icons…
[11/10/18 18:46:37.476][DEBUG] [Main Thread] Removing camera protection…
[11/10/18 18:46:37.547][DEBUG] [Main Thread] Monitoring system shutdown…
[11/10/18 18:46:37.547][DEBUG] [Main Thread] SequenceEnds complete…
