SGP Stuck on "Resume Sequence"
Whenever I abort a sequence, or reset progress on the sequence, the “Run Sequence” button changes to “Resume Sequence” and will not reset. I can run with the system button as is but all commands that rely on “run” vs. “resume” fail to execute. What might I be doing incorrectly?
Hi - have you tried the drop down menu button at the top that resets the sequence but not progress? That changes the resume to a run again.
Thank you. That works.
