no this is at the beginig of a sequence that’s ther’s a problem :
If i understand well, there’ no guiding launch at the beginig of the sequence, then a recovery is trigged to force start the
autoguider… why the guider does’nt launch automatically ?
[24/03/2015 21:13:32] [DEBUG] [Sequence Thread] ********** Run sequence started **********
[24/03/2015 21:13:32] [DEBUG] [Sequence Thread] DoEventGroupChange: Changing to event group: Target Set 1
[24/03/2015 21:13:32] [DEBUG] [Sequence Thread] Checking for start delay…
[24/03/2015 21:13:32] [DEBUG] [Sequence Thread] Delay found… waiting 11 seconds…
[24/03/2015 21:13:32] [DEBUG] [Sequence Thread] Delayed start. Commencing sequence in 11 seconds…
[24/03/2015 21:13:43] [DEBUG] [Sequence Thread] DoEventGroupChange: Complete
[24/03/2015 21:13:43] [DEBUG] [Sequence Thread] Attempting to find next event…
[24/03/2015 21:13:43] [DEBUG] [Sequence Thread] Current event[0] frame count: 0/1…
[24/03/2015 21:13:43] [DEBUG] [Sequence Thread] Looking at event[0]…
[24/03/2015 21:13:43] [DEBUG] [Sequence Thread] Found event event[0] with remaining frames.
[24/03/2015 21:13:43] [DEBUG] [Sequence Thread] Event[0] frame count: 0/1…
[24/03/2015 21:13:43] [DEBUG] [Sequence Thread] Getting first event (0)…
[24/03/2015 21:13:43] [DEBUG] [Main Thread] PopulateDataModel: Transferring view to the data model…
[24/03/2015 21:13:43] [DEBUG] [Sequence Thread] Running capture event…
[24/03/2015 21:13:43] [DEBUG] [Sequence Thread] ------------- Starting capture frame for event[0] -------------
[24/03/2015 21:13:43] [DEBUG] [Sequence Thread] Created base name for frame capture: Target Set 1_300sec_1x1__frame1
[24/03/2015 21:13:43] [DEBUG] [Sequence Thread] Created directory for frame capture: F:\Users\fdx1\Desktop\PHDLab_Win\Light
[24/03/2015 21:13:43] [DEBUG] [Sequence Thread] Sending commands…
[24/03/2015 21:13:43] [DEBUG] [Sequence Thread] SetFlatBox: Frame Type is non-flat
[24/03/2015 21:13:43] [DEBUG] [Sequence Thread] Checking for auto manual focus (pre)…
[24/03/2015 21:13:43] [DEBUG] [Sequence Thread] Resuming auto guiding (settling)…
[24/03/2015 21:13:43] [DEBUG] [Sequence Thread] PHD2 GetPhdStatus - Pre-Wait : Stopped
[24/03/2015 21:13:43] [DEBUG] [Sequence Thread] Sending to PHD2:
{“method”: “get_app_state”, “id”: 1001}
[24/03/2015 21:13:43] [DEBUG] [Sequence Thread] PHD2 GetPhdStatus - Post-Wait: Stopped
[24/03/2015 21:13:43] [DEBUG] [Sequence Thread] PHD2: Requested unpause, but PHD2 reports it is not in a paused state
[24/03/2015 21:13:44] [DEBUG] [Sequence Thread] PHD2 GetPhdStatus - Pre-Wait : Stopped
[24/03/2015 21:13:44] [DEBUG] [Sequence Thread] Sending to PHD2:
[24/03/2015 21:13:44] [DEBUG] [Sequence Thread] PHD2 GetPhdStatus - Post-Wait: Stopped
[24/03/2015 21:13:45] [DEBUG] [Sequence Thread] PHD2 GetPhdStatus - Pre-Wait : Stopped
[24/03/2015 21:13:45] [DEBUG] [Sequence Thread] Sending to PHD2:
[24/03/2015 21:13:46] [DEBUG] [Sequence Thread] PHD2 GetPhdStatus - Post-Wait: Stopped
[24/03/2015 21:13:46] [DEBUG] [Main Thread] PopulateDataModel: Transferring view to the data model…
[24/03/2015 21:13:46] [DEBUG] [MF Update Thread] Performing serialize…
[24/03/2015 21:13:47] [DEBUG] [Sequence Thread] PHD2 GetPhdStatus - Pre-Wait : Stopped
[24/03/2015 21:13:47] [DEBUG] [Sequence Thread] Sending to PHD2:
[24/03/2015 21:13:47] [DEBUG] [Sequence Thread] PHD2 GetPhdStatus - Post-Wait: Stopped
[24/03/2015 21:13:48] [DEBUG] [Sequence Thread] PHD2 GetPhdStatus - Pre-Wait : Stopped
[24/03/2015 21:13:48] [DEBUG] [Sequence Thread] Sending to PHD2:
[24/03/2015 21:13:48] [DEBUG] [Sequence Thread] PHD2 GetPhdStatus - Post-Wait: Stopped
[24/03/2015 21:13:48] [DEBUG] [Sequence Thread] Request to settle auto guider has failed. Guider reports it is not guiding…
[24/03/2015 21:13:48] [DEBUG] [Sequence Thread] Recovering the sequence (while attempting to dither or settle the auto guider)
[24/03/2015 21:13:59] [DEBUG] [Recovery Sequence Thread] (Recover) user try again…
[24/03/2015 21:13:59] [DEBUG] [Recovery Sequence Thread] Something bad has happened… attempting to recover the sequence (attempt 1)…
[24/03/2015 21:13:59] [DEBUG] [Recovery Sequence Thread] Recovery method using guider has started…
