SGpro causing PHD2 to crash, I think
I’m not sure where to post this, SGPro or PHD2, so I’ll start here.
For my normal imaging workflow I typically have the mount ready, SGPro running and ready to start, (sequence loaded and equipment connected), PHD2 running, Stellarium Scope and Stellerium running. I have the mount pointed at my imaging target via by using either Stellarium or the Hand Controller. I then kick off a focusing run. After focusing is done I kickoff PHD2 to get the guiding going. I like to verify tracking is working before starting the sequence.
Once the focusing is done and I know PHD2 is working. I start the sequence. For the target I only use the center now since I am typically close to the target with the goto so there is no need to use the slew to option. Anyway as soon as I select the Run Sequence button and the Center Now kicks off, PHD2 crashes. It doesn’t matter if I have PHD2 tracking or not . However, Center Now carries on and is not effected by the PHD2 crash.
Once PHD2 crashes, I need to restart PHD2 and reconnect the Guide Camera, Mount. I am able to restart PHD2 while SGPro continues to work on the centering. Once centering is complete SGPro then, I guess, ask PHD2 to begin tracking and everything proceeds normally.
PHD2 crashes only when the Center Now is invoked. I’m not currently at my observatory PC so I don’t have any logs but will post if needed. It is suppose to be a clear night tonight, if so I can get new logs if needed.
BTW I am running SGPro v2.6.0.24 and PHD2 developer 7.
The PHD2 crashing is consist when PHD2 is running and SGPro Center Now is invoked.
Mark
I have had the two programs get out of sync in the past. I have only experienced hangs when I have fiddled with PHD2 before running a sequence. I have had total reliability if I let SGP do it all. This is what I would propose as best practice:
  1. Slew to a low declination guide star, set up PHD2 profiles, calibrate the guider, set the option to remember the calibration and then shut it down.
  2. Set up SGP sequence and equipment profile (you might need to check the assumed PHD2 profile that is uses too)
  3. Ensure PHD2 is not running and then run the sequence. SGP will connect all the equipment and fire up PHD2 automatically.
Doing it this way - I have had hundreds of unattended hours over many nights of perfect operation.
There are occasions when PHD2 will not settle - in those cases, I have had some success starting PHD2 guiding and then starting the sequence. If I recall correctly, certainly on older versions, if I have PHD2 on but not guiding, SGP does not always synchronize status with it and mistakenly report the error. (that may be fixed now)
I ran the very same version combination last night when I was doing the videos, proving it works:
“http://www.digitalastrophotography.co.uk/Astrophotography/Setup_Videos_files/SGP%20startup.mp4”
I never had issues with PHD2 already guiding before running SGP sequence. I always manually pick a guide star and start guiding before running SGP sequence because I wanted to make sure that PHD2 is guiding properly before running SGP sequence.
Peter
Thanks @buzz & @topboxman
I never had PHD2 crash up until recently. I’m wondering if it might be the new guide camera. I recently switched from a guidescope setup to a OAG and went from the Orion StarShoot Autoguider camera to a QHY5III174. I’m now wondering if it might have something to do with the QHY camera. PHD2 recently added in the native support for QHY. I might need to post over on the PHD2 forum.
Mark
I’m posting so others might be aware of a potential conflict I found that appears to cause PHD2 to crash.
I’ve been having issues where PHD2 wants to crash when SGPro starts. What I found was a mistake on my part. When I changed over from using a guidescope to a OAG setup, (using different cameras), I forgot to change the PHD2 Connection Settings in SGPro’s Equipment Profile Manager. It appears when SGPro starts it must send PHD2 the profile that is in SGPro but this profile is no longer valid in PHD2 which causes PHD2 to crash. Once I fixed the PHD2 Connection Settings in SGPro to have the correct equipment profile everything worked as they did before.
Mark
thanks for sharing -
similarly, I went back to my records - I can get SGP and PHD confused if I interject during a sequence and mess about with PHD2 - the result being that SGP assumes the wrong status and eventually times out. I assume that there is some logic that doesn’t assume customers changing things on the fly - so down to me really.
