I’m having a bewildering issue with autofocus and am hoping someone has some ideas as to what could be happening. My scope is a CFF135 with a Feathertouch FTF3215 and Starlight Instruments Handy Motor on it, controlled by an Optec FocusLynx controller. I’ve been using this for 2+ years without issue.
Recently I have started getting autofocus failures that are now happening more and more often. On taking a closer look, the autofocus images do not show stars as points but rather as little lines, in most cases 2-3 star widths long. This effect is most pronounced when the focuser returns to the focus point to take a validation image. The validation image shows lines instead of stars and the autofocus run fails because of it. So something somewhere is shifting. This happens while the scope is actively guiding or with guiding off.
I noticed that there was a little bit of binding in the focuser drawtube travel and so I took the focuser apart, cleaned and re-greased it. Now the focuser is buttery smooth yet firm. There is no lateral shift in the drawtube that I can detect. But unfortunately the problem still persists. I’m really at a loss to figure out what the problem is.
Any thoughts?
