Success comes after multiple checks
I have reported a number of problems in various posts over several months of which a few resulted in replies. The UK east coast weather has provided very few opportunities for me to progress but I have managed to do so. After yet again going very carefully through the control panel profiles and checking and re-checking image scales, I developed a set of equipment profiles and have been able to impose these on schedules. As a result, from my first opportunity to test out a decent run, everything has worked - including things that I did not realise existed!
The last run included 4 targets, fairly near each other, via the mosaic wizard. In each case the target was faithfully centred (OK - centered if you prefer) and I went back indoors to watch (after setting the dome for the first target. It did its stuff and the image set was collected. On the next target an amazing thing happened. While watching remotely (indoors) SGP decided that the mount needed to do a meridian flip. It did so as I was running outside. I managed to reposition the dome in time for the automated ‘centre here’. check. It then centred and continued imaging. The rest of the session went smoothly as well - not a single failure.
Although this run didn’t require any guiding (f2 60 - 90 seconds) I had already seen a session do automatic star detection and guiding flawlessly. The only problem here is the need to move the dome to match the slit with the extra width of the guide scope.
All in all I count this as my first totally successful run and it left me on a ‘high’ :grinning:
Lawrence Harris
Lawrence, Congratulations. Sounds like you got there!
One of your main issues was centering in the wrong place. Are you happy with the process now and if so, can you describe the solution?
Hi
Centering is the only function that I have not specifically re-tested.
I will make a note to try it next time.
Lawrence
Well done Lawrence, now get a motor on the dome and get it to slave to the mount. No requirement to “run outside”, although it is always scary that everything is moving out there (meridian flip) on its own.
I wouldn’t know where to start on motorising the dome. I’m not mechanically minded :cold_sweat:
Lawrence (waiting for warmer weather here in UK)
Not sure what your dome is, but the drive from Pulsar, although expensive, works a treat. See Pulsar Dome Drive
I’ll try to reply privately to this one :thinking:
Lawrence
