Im using SGP and Dragonfly to slave roll-off roof to park/unpark action. It works well, as i tried in mount simulator, but i have question: will SGP wait for RoofStatus to get OPENED state or it going to unpack mount just after issuing command to RoofOpen? Maybe its possible to set some delay between sending command to Dragonfly and unparking mount?
jarek
If you’re using the “Open Roof First” it will wait for RoR to report that it is Open before it unparks the roof. And likewise for the “Park Mount First” option.
You should always validate this though as different hardware can implement things differently. For instance if SGP tells the roof to Open and it immediately reports “Open” vs “Opening” or “Moving” then this will cause SGP to immediately unpark the mount which is not ideal. Thankfully I haven’t found many devices that actually behave in this manner, but with the vast amount of hardware out there it’s always best to validate.
I thought so, but wanted to be sure
Thanks a lot!
