Target folder
Very minor issue.
In the past when I setup a new sequence, I would create an empty folder for an object and once I ran the sequence, a subfolder labeled “Light” would be created (as would Bias and Dark for calibration data) in the new folder. Now the subimages are stored in the original empty folder and no “Light” subfolder is created. No big deal but I could have sworn the subimages folder was created by SGP - but I could be wrong!
Any ideas?
John
In the “File Name” box, you’re probably missing a reference key for frame type as a directory/folder.
For example :
%tn_%ft
would create files named TargetName_Light. in the base folder.
But:
%tn\%ft\%tn_%ft
would create TargetName_Light. in the TargetName\Light\ subfolder.
You can click the little key button (it looks like a microphone, but it’s a key) next to the File Name text box to see the complete list of keys, and an example showing how to use the keys as folder names and parts of file names.
THANKS! I knew it had to be something obvious I was missing!
John
