Time use SGP versus Time use Windows
After two weeks we have differences between the time that SGP uses versus the time use the computer.
First problem:
The object when it is before the meridian indicates that there is one hour to transit, but the SGP the flip indicates 2 hours to transit, we have a difference of one hour, to solve the flip correct time it is necessary to indicate -60 the flip parameters before the meridian to perform the turn.
Second problem
After the flip is done, SGP arrives at an area after one hour where the object is located, that play solve can not resolve where the telescope arrived after the flip and it is necessary to locate the object manually.
I attach the log and print screen with the information.
Leandro
Captura
The log files.
Leandro
I’m guessing this is a setting issue, otherwise everyone outside the UK would have a problem. Just a guess, have you set your location in the user profile?
Yes, I have set muy location in The user profile a long time.
Regards
Leandro
Envoye de mon iPhone
If the difference between the Mount (Telescope) and your laptop (and hence SGPro) is one hour, and if you noticed this problem only recently, then it sounds like your region has recently changed its clock from winter-time to summer-time. Your laptop will have automatically updated to ‘summer time’ but you will need to tell your mount as it won’t update automatically and even though you put in ‘local time’ when powering up your mount, it will assume this is winter time and will therefore be one hour adrift of real local time. Just a thought.
good point - my mount is a Paramount, so its time is always the PC time.
Any news at my error?
Leandro
