Hoping theres a easy way.
Ok - I setup equipment and give it a name. (I use same all the time).
I create a dozen sequences (per target name and save them as per target name).
I now want to enter filter offsets. I load and enter my equipment manager primary
file and edit it - add filter off sets. Maybe autofocus step size… and SAVE.
This (if I understand it right) will update newly created sequences… but dozen
sequences I have already created and saved do not get updated?
I thought I was good - After adding the filter offsets. I load a previous target seq file…
none of my equipment profile updates are there?
I believe I can use equipment MANAGER and enter the data AGAIN. Then save that seq.
But if I load another target seq from my library the data isn’t there.
It would seem I have to re-enter all the filter off sets (any other edits like auto focus set size)
in every one of my saved sequences. I’m SURE there is a easier way?
Some how I’m confused as to how all the files “merge/work together”. the user profile, the equipment profile
and the control panel/manager thing. so far I use ONE user profile, ONE equipment profile.
I THINK these are used when creating a NEW sequence. (pulling the profile data I entered).
I enter a TARGET name and RA/DEC and save as target name. I have a dozen-20 of these.
am I doing this right? or do they pick and choose data from all the files?
Adding filter offsets to previously created .seq files is a nightmare.
