In the filter settings box, you include things such as autofocus duration, filter offsets, flat panel related data etc… it would seem to be this would be the perfect place to include default options on:
- Gain per filter. Typically people will use on gain setting for LRGB and another for Narrowband. This data would be included directly in the per event, per filter data. Obviously, the user could still modify that info using the setting box as per now.
- Standard frame duration per filter. I realise that you may use different durations for something very bright vs something more dim. However, in my experience, in 90% of cases, the same duration per filter applies. It would just speed up the whole process and users could still modify using existing tools.
