Just wondering if anyone has had any issues with W 10 Creator’s update and SGP (or any other astro software for that matter).
I updated a couple of other PCs in the house but wanted to be sure before updating the observatory machine!
I have gotten pretty spooked about W10 updates ever since an update (not creator’s) totally failed and I had to do a clean reinstall. Not to mention they take forever…
Drivers not an issue since it is a new PC that I just built.
UPDATE: Finished the PC and updated it to Creator’s Edition and everything works fine.
One thing I do like is that previously you could only specify active hours (thus banning update reboots that destroy your imaging session) as a 12 hour span and that is now 18 hours. That is helpful for those long winter imaging sessions. Not sure if this is specific to Creator’s but it is sure a help when imaging.
You might consider totally disabling the automatic updates to prevent all kinds of unexpected side effects. Also remember the old adage – if your computer is working, you probably don’t need those updates. So manually downloading the updates once every three or four months is probably sufficient.
You can disable auto updates by editing the “group policy.” This is a bit complicated but you can Google the subject to get the details.
Gotcha. I re-enable Windows Services to re-enable Windows Update about once a month. I find it better or more reliable if I manually do Windows Update when nothing else is running in my laptop and never had issues.
