What controls the file naming pattern?
If I enter a “Custom file name pattern” in Sequence Generator Options and there is a different file naming pattern in Equipment Profile Manager, which takes precedence? For file naming purposes, does it matter if the “Use profile as default for new sequences” is checked or not?
The current sequence will take precedence. Be aware, once you create a
sequence based on a profile, that new sequence is completely independent
from the profile used. So if you make changes to the profile it will NOT
affect the existing sequence and vice/versa.
