Hello.
I need a feature for re-framing my object.
Why do I need this feature.
More than once I have to break sequence and rebalance the telescope.
While I balance the telescope, the tracking of the object is stopped.
When the telescope is well balanced again, I can restart sequence.
Unfortunately, when I restart the SGP sequence there is no re-framing of the object.
If it was possible, I am asking for such a function.
When I resume a sequence on the same object the SGP should ask me if the SGP should recalculate and frame the object.
Hello.
I’m sorry to only write back now, but recently I came home late from work.
My assembly is ASA DDM - I don’t need to use autoguiding.
DDM must be precisely balanced in order not to use autoguiding.
Unfortunately, in some positions of the telescope, the DDM is not precisely balanced.
In order to balance the telescope well, you need to spend a lot of time on this problem - for professional reasons, I don’t have too much time for it.
It remains for me to interrupt the photo session from time to time and re-balance the telescope.
If this is not a big problem, I repeat the request for a function in SGP.
When I resume sequence on the same object.
The SGP should ask whether to recalculate and frame the object.
best regards
Wojtek.
