Thanks Dave, that’s good to know.
Are you running 32 or 64 bit, I cant tell from the Release number?
Interestingly I have just tried again, this time on my Desktop PC and it is working, but it doesn’t work on two Laptops one of which has the same software as the desktop. Very odd, perhaps something in the config?
Yes selection box zoom. Both laptops are using their own screens, one is a Dell XPX 13”, quite small but the other is a full size laptop. I have been through all the settings and can’t see anything unusual.
All three machines, including the Desktop that works, are using the same profile from my NAS so all those settings are the same.
Hm, there are no settings for that. Can you tell where it’s zooming to? Is the image display rotated in SGP? For instance if you were to make a selection in the top left corner where does it go?
Also what is the resolution of that display and what, if any, scaling are you using on it?
No rotation and it zooms to an area slightly lower and to the right of the selected area.
I use scaling and can confirm this is the issue, it works fine with scaling off. These are the settings I use, which are recommended due to high definition screens.
I will take a look at this issue and see if I can fit it in the beta. Scaling the selection shouldn’t be that difficult… we do it in a hundred other places already… just overlooked this one.
No, sorry. I am stretched pretty thin right now and have several things higher on the priority list for the 4.1 release. We haven’t forgotten it though.
