I’m new to SGP and did a bunch of tests last night between clouds.
\o/ the good news:
Autofocus works like a charm ![]()
Plate solving with astrometry.net/ansvr work as good as with astrotortilla.
But i’m confused by the sequence step…
I know that i can prepare the sequence in advance with the framing & mosaic module.
But on the field i generaly didn’t have internet connection so framing & mosaic is not an option.
So i point with skychart and blind solve sync the mount.
At this time i’m spot on the target, but i did find any shortcut to make a sequence for light acquisiiton from there. (i need to enter the coordinate manually as i’ve solved the preview)
I try to find some shortcut for that usecase in the documentation but did not find any revelant information.
I understand that SGP is mainly used for a complete automation sequence…
But as a beginner i’m slowly adapting my usual workflow…
Have you a pointer or a procedure to program the sequence from a skychart software in the field without internet ?
Thank you in advance for your advice.
HoxCa
