Hi guys, I would like to point to couple of issues I had with 2.5.0.10.
I run Win7 x64 with Ascom 6.2 platform.
I see some guys report crash on download, mine don’t crash, but start to experience a hang for unreasonable amount of time while downloading. And this happens on very first frame, not always thou. If I just wait, (too long) the frame get downloaded eventually and all seems running smooth after. Not really sure what happens, just letting you know, in 2.4. that never happened.
I had sequence running with 5 events. First three were Ha, Green, Blue in that order. When first event almost finished I decided to switch places of event 3 and event 2, so instead of G it would start B. I left the pc and came back after half an hour and noticed that it continued to shoot G ignoring that I switched the order of events. Right clicked on setting of B event and clicked “Set as current event”. Waited that it finished the frame in hope it will switch to event B, but it didn’t.
Then I decided to abort the sequence and let current frame to finish, but after frame got downloaded, SGP didn’t stopped and Abort Sequence button stayed grayed out, couldn’t do anything and couldn’t stop the sequence. SGP continued to dither and shoot as if I never asked it to stop. To stop the sequence I disabled all next events and current one set to 1 repeat. Only then, when frame were finished, sequence stopped. I put back everything as planned again, run the sequence and it performed very well until morning.
My log files is here: https://www.dropbox.com/s/ve3z0gna2aw90g6/sg_logfile_20160212181115.txt?dl=0
maybe you can spot something unnusual that went wrong and why I couldn’t stop the sequence?
Thank you!
Sergio
