Continuing the discussion from Sequence Generator Pro 2.5.1.9 Beta is Released for Testing:
Hi There seems to be a problem opening RAW files now the following message box appears:
This is with the File → Open Image
I did not actually try to capture a real image yet. (These are NEF files not sure if that matters)
sg_logfile_20160501062119.txt (20.0 KB)
I opened several of my FIT files that were previously captured with Nebulosity and SGP with SGP 2.5.1.9 without issues.
You might want to upload the offending file for others to try.
Peter
Hi Peter. Thanks. Yes FIT files are fine. There was a recent change that affects how DSLR files convert RAW to FIT.
Can’t open Canon RAW either.
Just tried frame and focus, didn’t work either nor did a test sub.
I can provide a log if needed but it seems something obvious.
