3.007 crash
hi, i just purchased 3.0 license yesterday and installation was good, no error occurred. but when i double click on the sgp icon, i got a crash. i tried the administer mode but nothing changed. if anyone got the same problem or had solution, I’m very appreciated.
i didn’t install the latest Windows patch which maight destory the ascom platform. And I can run sgp 2.6 perfectly on my laptop.
Thank you
I have tried 3.0.0.7 on two PCs, a Win 7 x64 and Win 10 x64. Both running fine.
Not sure if it will help but I had a similar problem here. Turning off the display scaling in Windows made 3.0 run. After the first run I could turn on the display scaling again and it would still run.
thank you for your reply. i will try it on win 7 64x.
thank you very much. and i checked my display setting, i found my scale was 100% ( Windows recommended)
I’m not sure if chinese OS will not fit with sgp 3.0.:joy:
Having a similar issue here. 3.0.0.5 was fine but 3.0.0.7 throws an exception. Machine is a HP win 7 x64 home edition. If display resolution is set to 800x600, then at the exception screen you can ask to continue and SGP will start at which time the display resolution can be returned back to recommended 1920x1080.
My other machine which is a HP win 7 pro edition, and 3.0.0.7 runs without problem.
splash screen here: Dropbox - File Deleted
I got the same crash on 3.0.0.7. 3.0.0.5 works fine. I got the same issue in both Traditional Chinese Windows 7 64-bit and Windows 10 64-bit. Attached is the log file.
sg_logfile_20180202223528.txt (871 Bytes)
I have the same problem. SGP3.007 crashed while initializing API
I am using Windows 10 Home Edition with Chinese Environment.
SGP2.6 run perfectly before on this labtop
log:
[02-07-18 11:12:45.687][DEBUG] [Main Thread] Licensing: Machine ID found…
[02-07-18 11:12:45.691][DEBUG] [Main Thread] Checking for valid internet connection…
[02-07-18 11:12:50.758][DEBUG] [Main Thread] Error validating internet connection: 操作超时
[02-07-18 11:12:50.758][DEBUG] [Main Thread] Licensing: Request for licenses failed, looking for cookie…
[02-07-18 11:12:50.873][DEBUG] [Main Thread] Licensing: Cookie found…
[02-07-18 11:12:50.873][DEBUG] [Main Thread] Licensing: Applying licenses…
[02-07-18 11:12:50.873][DEBUG] [Main Thread] Licensing: Licenses applied…
[02-07-18 11:12:50.873][DEBUG] [Main Thread] SGPro retail license…
[02-07-18 11:12:51.675][DEBUG] [Main Thread] API successfully started on port 59590…
[02-07-18 11:12:52.394][DEBUG] [Main Thread] GlobalExceptionHandler caught : 未将对象引用设置到对象的实例。
[02-07-18 11:12:52.394][DEBUG] [Main Thread] Runtime terminating: True
I see internet connection error in last log file, so I connected VPN and tried again
the problem seems no business of networking
log:
[02-07-18 11:23:59.293][DEBUG] [Main Thread] Licensing: Machine ID found…
[02-07-18 11:23:59.293][DEBUG] [Main Thread] Checking for valid internet connection…
[02-07-18 11:23:59.640][DEBUG] [Main Thread] Valid internet connection detected…
[02-07-18 11:24:01.695][DEBUG] [Main Thread] Licensing: Request for licenses successful, writing cookie…
[02-07-18 11:24:01.695][DEBUG] [Main Thread] Licensing: Applying licenses…
[02-07-18 11:24:01.695][DEBUG] [Main Thread] Licensing: Licenses applied…
[02-07-18 11:24:01.695][DEBUG] [Main Thread] SGPro retail license…
[02-07-18 11:24:02.495][DEBUG] [Main Thread] API successfully started on port 59590…
[02-07-18 11:24:03.108][DEBUG] [Main Thread] GlobalExceptionHandler caught : 未将对象引用设置到对象的实例。
[02-07-18 11:24:03.108][DEBUG] [Main Thread] Runtime terminating: True
