Managed to Centre Here new Target, but Plate Solve on right click is faded out.
I’m using the latest Beta and all is well until I went to plate solve a new target to
populate the Target Settings.
Has anyone had this problem?
Scott.
Scott.
Where did the image come from? Did you have the values for your scale set correctly?
Can you post the image here?
Hi Jared,
I manually put the co-ordinates in the Target Settings, then hit Slew Now and Centre Now.
I then see what the framing is like and right click on the spot in the frame I want centred.
This all worked fine until I wanted to plate solve to populate the Target settings with the new
co-ordinates. At this point the Plate Solve box was faded out. I hadn’t seen this before?
Anyway, I did need to get the framing right, so, I closed down the programme and started
up a fresh to see if that would make a difference, as I believe I must have done something
out of ‘sequence’
On the second try the plate solve box was solid and I went on as usual.
Thinking back I think that perhaps the sequence was paused on the first try and then on the second
try I hadn’t started the sequence. I thought I could add a target on the fly, just don’t think I can plate solve populate once sequence has started.
Might try and see if I can replicate this.
Scott.
