I noticed today with beta .758 (32 bit) that the progress screen seems frozen regardless of what target I select. Even a target that I know I didn’t take any frames yet. If I mouse over any of the targets that I know are completed, then it does reflect the true progress status. In the screen shot attached, NGC4536 shows a progress when in fact it hasn’t taken one frame yet. The mouse over ngc4536-G on the left does show 0% completion status, which is correct.
Attached is a screen shot.
I was able to clear the issue by loading an older sequence. With the older sequence loaded I was able to get accurate progress statuses with each target selected. I went back to the current sequence that had the issue and now that is displaying the correct target progress statuses.
The current sequence is what was selected when I did the upgrades and had to edit and remove the deviceCache field.
