I’m new to SGP and I’m struggling with the mosaic function.
I have created successful a sequence of 4 frames mosaic of M81.
In the target list appears M81-1 to M81-4 with 10 pictures/per target to take. I can see in the background picture the first position. The saved filename is as expected M81-1…
But the there is no movement to the second subframe position of the mosaic and so on.
The saved filename is permantely M81-1… of all 40 pictures and shows always the same position of the mosaic.
As you can see every subtarget has its own position.
I have in all event checked “Run”, filled out Exposure and Repeats. (not show in some screenshots)
Hi.
I have had the same issue couple of months ago and did not find the solution.
The only way to do my mosaic was to perform the first target then stop the sequence, uncheck the first target, save the sequence, reload and re-run the sequence with the only second target checked.
Then redo the same for the third and so on…
Jared told me he did not find something wrong in the log file…
You have acutally set the targets to run as can be seen here. But all except the first target is registered as finished since there is no event for them. The V means that the target is finished (since there’s nothing setup for it)
No events setup for 95-2…same for 95-3 and 95-4.
I don’t think you understand that all targets have their own events since you have setup 4 events for M95-1 with the exact same settings.
If it were setup correcly you would setup 1 even for each target with those settings.
Screenshot 6 shows the initial window after successful target creation (5), all targets have the hook behind the targets.
My mistake is in screenshot 7, where I checked “Run” for the 4 events and entered Exposure and Repeats.
I thought everything is correct and run the sequence.
But when I clicked on the M95-2 properties, I realized that no “Run”, Exposure and Repeats is checked and filled out!
So SGP permantely stayed on M95-1! You are absolutelly right, Xplode!
I checked all remaining target properties and checked the items.
A correct sequence should look like in screenshot 10.
