I use AAG-cloudwatcher SOLO Lunatico with SGPpro
it gives well the UNSAFE info red dot at the bottom right, if clouds or other.
But the problem is that SGP lets the sequence start?
yes despite the UNSAF he opens the roof, goes on the target, turns the dome
and there
UNSAFE triggers and everything closes automaticly and well
But normally SGP should not open and start the beginning of the sequence if UNSAFE
Do you know why it closes only after
I can’t find in which config?
@DESGREES When the safety monitor reports unsafe, SGPro is designed to start the sequence and await safe conditions. It is important to note that this will only work if you enabled the setting to do this. Otherwise the safety monitor’s status is just information for you and not considered by SGPro. Please see here:
