Thank you for your hard work first. The ability to save the Equipment Profile locally so that we can use that profile to load our settings in other machines would be a great addition.
Thank you!
Thank you!
SGPro currently allows for you to specify the location of User and Equipment Profiles. Once you do this, you can easily get access to all of your profiles. A lot of people will then use an application like Dropbox to sync this user-defined folder across several different machines. If you don’t want to use an application for sync, you can just copy all files with extension .sgp and move them to a new machine manually.
The setting is here in General Options
You Guys are the best!!! the only thing I wish for is a Linux friendly SGP lol
