It is not clear to me what happened. I actually looked for quite some time. The logs indicate a new 10 min exposure at 00:20 and then there is literally no indication of the abort source in the logs. The sequence just stops… I do not know if this is a side effect of a pre-existing bug that has long been fixed, but it may be worth updating SGPro (the version used is ~5 months old and we fix bugs regularly). In any case, I will add additional logging so that if it happens again the logs will be less mysterious
