When Generating a sequence I always designate a sequence.
When I use the sequence It would be nice if the sequence display were modified to display
“Equipment - Profile” So that a user could (Me) could see That they are using the proper equipment profile at a glance.
In addition if a user makes a change to the profile in the sequence box, make some sort of indication that a piece of equipment has been changed from its definition in the designated equipment profile. For example if I make a change To the camera using the tool in the sequence box, you could change the text Red in the camera box.
