After updating to 2.3.14. SGP wont interface with PHD2
@Andy
These r the links to the Debug Logs
https://www.mediafire.com/?64t7zvx3rv7hied
https://www.mediafire.com/?mkzrpy9f2kkm72q
Is the problem that there is an occasional one pixel shift in the position of the guide star?
I ask because I’ve seen that with PHD1 using an interlaced Atik camera, with subframes, and the ASCOM driver. If I use full frame downloads it doesn’t happen.
BTW, where is the option to use binning in PHD2? I’m using 2.3.0 and can’t find it. Is it the 2x2 noise reduction option?
I would like to thank the hosts for their tolerance…I wouldnt want to turn this into a PhD forum…
I am glad however that there is such fruitful exchange of info
Jared,
I am of course using the latest snapshot build of PHD2, and just for kicks I decided to try out the new first run wizard. The wizard works great, but now I’m not getting the PHD graph in SGP. Nothing else changed. Should I just delete the PHD2 folder in my documents and let PHD create it again?
Yes, delete all PHD logs and make sure that the PHD2 log is being created in the default location (as you can override the log location in the PHD2 settings)
Oh duh, I forgot to enable the guide log in PHD2. Apparently after running the wizard the guide log is not enabled by default. It’s working now.
Hi Dmitris, I saw your logs, but I have not had time to finish looking at them. I’ll get back to you soon when I have had a chance to finish look at them.
Andy
