Hi Ken, this is the portion of log file
[07/16/24 23:22:10.846][DEBUG][Sequence Thread][SQ;] BlockUntilFocuserMovementDone: Focuser reports it is done moving, continuing...
[07/16/24 23:22:10.864][DEBUG][Sequence Thread][SQ;] Created base name for frame capture: 2024-07-16_m11_120sec_2x2_B_0020
[07/16/24 23:22:10.865][DEBUG][Sequence Thread][SQ;] Created directory for frame capture: C:\Users\Astro\Desktop\Deepsky\m11-Light\
[07/16/24 23:22:10.878][DEBUG][Sequence Thread][SQ;] Starting generic timed monitoring event for "Timeout! Failed to capture sequence frame." (THIS IS NOT AN ERROR MESSAGE)...
[07/16/24 23:22:10.878][DEBUG][Sequence Thread][SQ;] Clearing timed monitoring events...
[07/16/24 23:22:10.979][DEBUG][Sequence Thread][SQ;] Current timed monitoring events cleared, start new timed event "Timeout! Failed to capture sequence frame." (NOT AN ERROR)...
[07/16/24 23:22:10.981][DEBUG][Sequence Thread][SQ;] EventMarker(9) - t:m11 (12); e:2; f:19; o:
[07/16/24 23:22:10.981][DEBUG][Sequence Thread][SQ;] EventMarker(10) - t:m11 (12); e:2; f:19; o:
[07/16/24 23:22:10.981][DEBUG][Sequence Thread][SQ;] Finished sending frame capture. Entering wait mode...
[07/16/24 23:22:10.981][DEBUG][Sequence Thread][SQ;] EventMarker(11) - t:m11 (12); e:2; f:19; o:
[07/16/24 23:22:10.981][DEBUG][Camera Thread][SQ;] SGM_CAMERA_CAPTURE message received...
[07/16/24 23:22:10.984][DEBUG][Camera Thread][SQ;CC;] SetAscomGain to 102
[07/16/24 23:22:10.985][DEBUG][Sequence Thread][SQ;CC;] EventMarker(12) - t:m11 (12); e:2; f:19; o:
[07/16/24 23:22:11.021][DEBUG][Camera Thread][SQ;CC;] Camera gain set to 102
[07/16/24 23:22:11.021][DEBUG][Camera Thread][SQ;CC;] SetAscomOffset to 25
[07/16/24 23:22:11.039][DEBUG][Camera Thread][SQ;CC;] Camera offset set to 25
[07/16/24 23:22:11.039][DEBUG][Camera Thread][SQ;CC;] SetAscomNormalSpeed...
[07/16/24 23:22:11.039][DEBUG][Camera Thread][SQ;CC;] Cannot set readout speed, not supported by camera...
[07/16/24 23:22:11.041][DEBUG][Camera Thread][SQ;CC;] ASCOM Camera: exposure started, waiting...
[07/16/24 23:22:11.104][DEBUG][Sequence Thread][SQ;CC;] Clearing timed monitoring events...
[07/16/24 23:22:11.205][DEBUG][Sequence Thread][SQ;CC;] Current timed monitoring events cleared, start new timed event "Failure while integrating m11; Event 3; Frame 20 for 120s. Image has not downloaded in alloted time period." (NOT AN ERROR)...
[07/16/24 23:22:11.215][DEBUG][Sequence Thread][SQ;CC;] EventMarker(13) - t:m11 (12); e:2; f:19; o:
[07/16/24 23:22:20.082][DEBUG][Main Thread][SQ;CC;] PopulateDataModel: await serialization lock...
[07/16/24 23:22:20.082][DEBUG][Main Thread][SQ;CC;] PopulateDataModel: Transferring view to the data model...
[07/16/24 23:22:20.257][DEBUG][Auto Save Thread][SQ;CC;] SaveSequenceFile: Await save sequence lock...
[07/16/24 23:22:20.257][DEBUG][Auto Save Thread][SQ;CC;] FileManager.Serialize: Acquire working file name => C:\Users\Astro\Desktop\Deepsky.sgf.working
[07/16/24 23:22:20.257][DEBUG][Auto Save Thread][SQ;CC;] FileManager.Serialize: Await serialization lock...
[07/16/24 23:22:20.257][DEBUG][Auto Save Thread][SQ;CC;] Performing serialization of save object...
[07/16/24 23:22:20.553][INFO][Auto Save Thread][SQ;CC;] FileManager.Serialize: Write to working file took 295 ms...
[07/16/24 23:22:20.553][DEBUG][Auto Save Thread][SQ;CC;] FileManager.Serialize: Acquire backup file name => C:\Users\Astro\Desktop\Deepsky.sgf.working.bak
[07/16/24 23:22:20.554][INFO][Auto Save Thread][SQ;CC;] FileManager.Serialize: Backup original file took 297 ms...
[07/16/24 23:22:20.556][INFO][Auto Save Thread][SQ;CC;] FileManager.Serialize: Rename working file to C:\Users\Astro\Desktop\Deepsky.sgf took 298 ms...
[07/16/24 23:22:20.558][DEBUG][Auto Save Thread][SQ;CC;] Serialization took 300 msec.
[07/16/24 23:22:39.662][DEBUG][CP Update Thread][SQ;CC;] Caught exception while getting filter wheel position. FW is expecting to be STOPPED! Returning (4) : unspecified (System.Reflection.TargetInvocationException: Eccezione generata dalla destinazione di una chiamata. ---> System.Runtime.InteropServices.COMException: unspecified
--- Fine della traccia dello stack dell'eccezione interna ---
in System.RuntimeType.InvokeDispMethod(String name, BindingFlags invokeAttr, Object target, Object[] args, Boolean[] byrefModifiers, Int32 culture, String[] namedParameters)
in System.RuntimeType.InvokeMember(String name, BindingFlags bindingFlags, Binder binder, Object target, Object[] providedArgs, ParameterModifier[] modifiers, CultureInfo culture, String[] namedParams)
in System.Type.InvokeMember(String name, BindingFlags invokeAttr, Binder binder, Object target, Object[] args, CultureInfo culture)
in ASCOM.DriverAccess.MemberFactory.CallMember(Int32 memberCode, String memberName, Type[] parameterTypes, Object[] parms) in C:\ASCOM Build\Export\ASCOM.DriverAccess\MemberFactory.cs:riga 247)
in ASCOM.DriverAccess.MemberFactory.CallMember(Int32 memberCode, String memberName, Type[] parameterTypes, Object[] parms) in C:\ASCOM Build\Export\ASCOM.DriverAccess\MemberFactory.cs:riga 283
in ASCOM.DriverAccess.FilterWheel.get_Position() in C:\ASCOM Build\Export\ASCOM.DriverAccess\FilterWheel.cs:riga 114
in u0.jc()
[07/16/24 23:22:49.342][DEBUG][CP Update Thread][SQ;CC;] Caught exception while getting filter wheel position. FW is expecting to be STOPPED! Returning (0) : unspecified (System.Reflection.TargetInvocationException: Eccezione generata dalla destinazione di una chiamata. ---> System.Runtime.InteropServices.COMException: unspecified
in u0.jc()
[07/16/24 23:22:59.344][DEBUG][CP Update Thread][SQ;CC;] Caught exception while getting filter wheel position. FW is expecting to be STOPPED! Returning (0) : unspecified (System.Reflection.TargetInvocationException: Eccezione generata dalla destinazione di una chiamata. ---> System.Runtime.InteropServices.COMException: unspecified
in u0.jc()
[07/16/24 23:23:09.496][DEBUG][CP Update Thread][SQ;CC;] Caught exception while getting filter wheel position. FW is expecting to be STOPPED! Returning (0) : unspecified (System.Reflection.TargetInvocationException: Eccezione generata dalla destinazione di una chiamata. ---> System.Runtime.InteropServices.COMException: unspecified
in u0.jc()
[07/16/24 23:23:19.522][DEBUG][CP Update Thread][SQ;CC;] Caught exception while getting filter wheel position. FW is expecting to be STOPPED! Returning (0) : unspecified (System.Reflection.TargetInvocationException: Eccezione generata dalla destinazione di una chiamata. ---> System.Runtime.InteropServices.COMException: unspecified
in u0.jc()
[07/16/24 23:23:29.680][DEBUG][CP Update Thread][SQ;CC;] Caught exception while getting filter wheel position. FW is expecting to be STOPPED! Returning (0) : unspecified (System.Reflection.TargetInvocationException: Eccezione generata dalla destinazione di una chiamata. ---> System.Runtime.InteropServices.COMException: unspecified
in u0.jc()
[07/16/24 23:23:39.826][DEBUG][CP Update Thread][SQ;CC;] Caught exception while getting filter wheel position. FW is expecting to be STOPPED! Returning (0) : unspecified (System.Reflection.TargetInvocationException: Eccezione generata dalla destinazione di una chiamata. ---> System.Runtime.InteropServices.COMException: unspecified
in u0.jc()
[07/16/24 23:23:49.846][DEBUG][CP Update Thread][SQ;CC;] Caught exception while getting filter wheel position. FW is expecting to be STOPPED! Returning (0) : unspecified (System.Reflection.TargetInvocationException: Eccezione generata dalla destinazione di una chiamata. ---> System.Runtime.InteropServices.COMException: unspecified
in u0.jc()
[07/16/24 23:23:59.999][DEBUG][CP Update Thread][SQ;CC;] Caught exception while getting filter wheel position. FW is expecting to be STOPPED! Returning (0) : unspecified (System.Reflection.TargetInvocationException: Eccezione generata dalla destinazione di una chiamata. ---> System.Runtime.InteropServices.COMException: unspecified
in u0.jc()
[07/16/24 23:24:10.050][DEBUG][CP Update Thread][SQ;CC;] Caught exception while getting filter wheel position. FW is expecting to be STOPPED! Returning (0) : unspecified (System.Reflection.TargetInvocationException: Eccezione generata dalla destinazione di una chiamata. ---> System.Runtime.InteropServices.COMException: unspecified
in u0.jc()
[07/16/24 23:24:11.111][DEBUG][Camera Thread][SQ;CC;] ASCOM Camera: exposure complete, waiting for camera to report image ready...
[07/16/24 23:24:11.146][DEBUG][Sequence Thread][SQ;CC;] EventMarker(15) - t:m11 (12); e:2; f:19; o:
[07/16/24 23:24:11.150][DEBUG][Sequence Thread][SQ;CC;] Waking from exposure time sleep period...
[07/16/24 23:24:11.151][DEBUG][Sequence Thread][SQ;CC;] Checking to see if the CCD has a temp...
[07/16/24 23:24:11.151][DEBUG][Sequence Thread][SQ;CC;] Saving the CCD temp...
[07/16/24 23:24:11.184][DEBUG][Sequence Thread][SQ;CC;] Entering super dangerous loop to await image completion...
[07/16/24 23:24:11.199][DEBUG][Sequence Thread][SQ;CC;] EventMarker(16) - t:m11 (12); e:2; f:19; o:
[07/16/24 23:24:12.261][DEBUG][Camera Thread][SQ;CC;] ASCOM Camera: Data type -> System.Int32[,]
[07/16/24 23:24:12.261][INFO][Camera Thread][SQ;CC;] ASCOM Camera read image data took ,53 seconds
[07/16/24 23:24:12.261][DEBUG][Camera Thread][SQ;] SGM_CAMERA_CAPTURE complete...
[07/16/24 23:24:12.261][DEBUG][Camera Thread][SQ;] Camera thread is IDLE...
[07/16/24 23:24:12.764][DEBUG][Sequence Thread][SQ;] EventMarker(17) - t:m11 (12); e:2; f:19; o:
[07/16/24 23:24:12.764][DEBUG][Sequence Thread][SQ;] Image reported as complete. Continuing...
[07/16/24 23:24:12.772][DEBUG][Sequence Thread][SQ;] Collecting FITs headers...
[07/16/24 23:24:12.773][DEBUG][Sequence Thread][SQ;] ASCOM Camera: Could not get last exposure start time. Reported as (unknown)
[07/16/24 23:24:12.773][DEBUG][Sequence Thread][SQ;] DATE-LOC time provided by SGPro (failed to retrieve valid entry from camera)...
[07/16/24 23:24:12.789][DEBUG][Sequence Thread][SQ;] ASCOM Camera Readout mode query...
[07/16/24 23:24:12.790][DEBUG][Sequence Thread][SQ;] ASCOM Camera: Readout mode is 0
[07/16/24 23:24:12.790][DEBUG][Sequence Thread][SQ;] ASCOM Camera: Readout mode mapped to "Mode0"
[07/16/24 23:24:12.790][DEBUG][Sequence Thread][SQ;] ASCOM Camera Readout mode query...
[07/16/24 23:24:12.791][DEBUG][Sequence Thread][SQ;] ASCOM Camera: Can Fast Readout is False
[07/16/24 23:24:12.803][DEBUG][Sequence Thread][SQ;] GatherFitsHeaders: Writing header info for last solve...
[07/16/24 23:24:12.803][DEBUG][Sequence Thread][SQ;] GatherFitsHeaders: Writing header info from UI...
[07/16/24 23:24:12.859][DEBUG][Sequence Thread][SQ;] EventMarker(175) - t:m11 (12); e:2; f:19; o:
[07/16/24 23:24:12.859][DEBUG][Sequence Thread][SQ;] Clearing timed monitoring events...
Tan’t upload the log file, extension not allowed
Marco
