Can someone please check the log file and tell me if it is a software or hardware problem, so I know what to do? Is the 2GB RAM enough for the software to run?
I posted a similar reply to Magicstar on BII but Iām repeating it here in case anyone is running successfully with the amount of RAM and SDD combination that Magicstar uses. He only has 10GB space available before running SGP. I was wondering if he may not have enough space for swap files as the night goes on. I believe this could cause his error. I have a similar stick with 2GB memory but have 15GB of HD space to start and I donāt have any problems.
The ASI1600 likes ram. It also likes 64 bit architectures because of this. Do you happen to know of your running a 32 bit or 64bit os? We had issues with the 1600 and ended up having to set some flags for SGP to be able to access additional ram on 64 bit systems above the 3.5gig limit opposed on 32 bit apps.
These āsticksā are fairly popular. They usually have 2GB RAM with a 64bit Atom processor running a 32 bit version of windows 10. A number of people use them with SGP without a problem. I also had āfail to save imageā issues with some versions of SGP, but .17 and after work fine for me. The only time I get āfail to save imageā is with the odd flat. Not enough to be an issue. I think the ASI1600 handles very short exposures different than long ones so maybe thats what causes it.
So, since .17 I have taken many hundreds of ālightsā without a single āfail to save imageā. I use platesolve2 and astrometry local with full libraries for 3 sizes of scopes, as well as the autofocus functionality. I use EQMOD and PS2 all controlled through SGP. The only other thing I have running is āsplashtopā to control the āstickā from a laptop in my house.
When starting SGP I have used about 52% of memory and have over 15GB of free space on the SDD. When SGP is running ātask managerā shows my āstickā using 65%-75% memory. I havenāt tried using a mini sd card yet. I use usb2.
The OP should be able to use his āstickā but has to check his memory and SD usage. No room for extra stuff on these things. I donāt know what impact running win 8.1 will have.
I am very dissapointed about this situation. I made clean format of my compute stick and add only the necessary apps. This gaves me a 20GB free space. I lost another weekend due to this isuue
What is going on??? Please help me. I have lost too many weekends withgood weather.
Ass you can see in my log file, the problem is:
[08/20/17 03:05:14.896][DEBUG] [Camera Thread] Cannot set readout speed, not supported by cameraā¦
then this:
[08/20/17 03:09:15.033][DEBUG] [Sequence Thread] Entering super dangerous loop to await image completionā¦
Two days know, waiting for your reply, I am doing some tests. I figure out that the problem occurs when the āSequense images use new tabsā is checked.
Please read my logs and let me know what is that problem.
The failed to save image generally happens when the USB bandwidth is set too high on the camera ASCOM driver. If youāre using a āstickā pc with a very low amount of ram (4 gigs and below) youāll likely need to take precautions to keep the memory usage very low.
The driver will set a different USB Rate based on USB2 or USB3. My guess is that the USB3 rate is too high and likely causing the failure. You can turn down the USB Rate in the ASI ASCOM driver.
As I said on your post on CN - Iām convinced the issue is due to having only 2GB of RAM on the Intel compu stick. Sorry, but 2 GB of RAM is not even recommended to run the O/S aloneā¦you are simply being very unrealistic imho. I base this comment on 15+ years working in the IT industry. Iām not trying to be mean by any means, but I am being brutally honest with you, because I think that will best help you out in the long run.
I wouldnāt even consider running Windows 10 on a normal PC with 2GB ramā¦let alone a very under powered ATOM CPU thatās as weak as a wet paper bag!
Anything to do with imaging (terrestrial, astro imaging) or video processing or 3d rending WILL be highly memory and CPU intensive.
The problem was on USB Limit of SGP. I reduce it down to 40 and works very well. With other products like MaximDL, Nebulocity, SharpCap I can go to 80% with no problem at all.
Also the download time of SGP is around 8 seconds, and on Nebulocity is 1-2 seconds.
All these sounds to you as a RAM issue??? OK listen also to this.
I put a laptop with 8GB RAM and I had 6 seconds of download image!!
