At a guess I am going to suspect you will say this is a ZWO Driver issue, but I am going to throw this out there, I am getting regular failures of image saves when performing flats, you can see from the logs here that an ASCOM driver error is reported
4.0.0.676 - 32Bit and 64Bit also see this in 680 as well
Camera: ZWOASI6200MC Pro
System: PrimaluceLabs Eagle4 Pro
ASCOM Platform: 6.5 SP1
ASCOM Driver for ZWO: 6.5.1.8
[08/29/21 14:48:51.287][DEBUG][Camera Thread][SQ;CC;] ASCOM Camera: exposure started, waiting...
[08/29/21 14:48:51.304][DEBUG][Sequence Thread][SQ;CC;] EventMarker(13) - t:Flats (0); e:1; f:9; o:
[08/29/21 14:48:58.427][DEBUG][Sequence Thread][SQ;CC;] EventMarker(15) - t:Flats (0); e:1; f:9; o:
[08/29/21 14:48:58.430][DEBUG][Sequence Thread][SQ;CC;] Waking from exposure time sleep period...
[08/29/21 14:48:58.430][DEBUG][Sequence Thread][SQ;CC;] Checking to see if the CCD has a temp...
[08/29/21 14:48:58.430][DEBUG][Sequence Thread][SQ;CC;] Saving the CCD temp...
[08/29/21 14:48:58.434][DEBUG][Sequence Thread][SQ;CC;] Entering super dangerous loop to await image completion...
[08/29/21 14:48:58.435][DEBUG][Sequence Thread][SQ;CC;] EventMarker(16) - t:Flats (0); e:1; f:9; o:
[08/29/21 14:48:58.550][DEBUG][Camera Thread][SQ;CC;] ASCOM Camera: exposure complete, waiting for camera to report image ready...
[08/29/21 14:49:00.608][DEBUG][Camera Thread][SQ;CC;] ASCOM Camera Error : Unable to cast object of type 'System.Object' to type 'System.Int32[,]'.
at tc.jk(rk A_0, tm& A_1, tm[] A_2)
[08/29/21 14:49:00.608][DEBUG][Camera Thread][SQ;CC;] ASCOM Camera: Attempting to abort exposure...
[08/29/21 14:49:00.608][DEBUG][Camera Thread][SQ;CC;] ASCOM Camera AbortImage: Camera state is 0
[08/29/21 14:49:00.608][DEBUG][Camera Thread][SQ;CC;] ASCOM Camera: Camera state is idle, abort not needed...
[08/29/21 14:49:00.608][DEBUG][Camera Thread][SQ;CC;] ASCOM Camera: Blocking until image is aborted...
[08/29/21 14:49:00.608][DEBUG][Camera Thread][SQ;CC;] ASCOM Camera: Image is aborted...
[08/29/21 14:49:00.608][DEBUG][Camera Thread][SQ;CC;] Error while attempting to capture frame...
[08/29/21 14:49:00.608][DEBUG][Main Thread][SQ;CC;] Adding sequence level notification: Error attempting to capture image (see logs for more information).
[08/29/21 14:49:00.622][DEBUG][Camera Thread][SQ;CC;] Sending Notification: Error - Error attempting to capture image (see logs for more information).
[08/29/21 14:49:00.622][DEBUG][Camera Thread][SQ;] SGM_CAMERA_CAPTURE complete...
[08/29/21 14:49:00.622][DEBUG][Camera Thread][SQ;] Camera thread is IDLE...
[08/29/21 14:49:00.942][DEBUG][Sequence Thread][SQ;] EventMarker(17) - t:Flats (0); e:1; f:9; o:
[08/29/21 14:49:00.942][DEBUG][Sequence Thread][SQ;] Image reported as complete. Continuing...
[08/29/21 14:49:00.951][DEBUG][Sequence Thread][SQ;] Collecting FITs headers...
[08/29/21 14:49:00.951][DEBUG][Sequence Thread][SQ;] ASCOM Camera: Could not get last exposure start time. Reported as (unknown)
[08/29/21 14:49:00.951][DEBUG][Sequence Thread][SQ;] DATE-LOC time provided by SGPro (failed to retrieve valid entry from camera)...
[08/29/21 14:49:00.952][DEBUG][Sequence Thread][SQ;] GatherFitsHeaders: Error gathering headers...
[08/29/21 14:49:00.952][DEBUG][Sequence Thread][SQ;] ** Property read ASCOM.ASICamera2_2.Camera Offset is not implemented in this driver.
[08/29/21 14:49:00.952][DEBUG][Sequence Thread][SQ;] Clearing timed monitoring events...
[08/29/21 14:49:00.952][DEBUG][Sequence Thread][SQ;] Error saving ASCOM image. : Object reference not set to an instance of an object.
at tc.hw(rr A_0, List`1 A_1)
[08/29/21 14:49:00.952][DEBUG][Sequence Thread][SQ;] Failed to save image to disk!
[08/29/21 14:49:00.990][DEBUG][Sequence Thread][SQ;] EventMarker(18) - t:Flats (0); e:1; f:9; o:
[08/29/21 14:49:00.993][DEBUG][Sequence Thread][SQ;] EventMarker(19) - t:Flats (0); e:1; f:10; o:
[08/29/21 14:49:00.993][DEBUG][Sequence Thread][SQ;] EventMarker(20) - t:Flats (0); e:1; f:10; o:
[08/29/21 14:49:00.993][DEBUG][Sequence Thread][SQ;] Running post event...
