I see you are not going to develop a featured requested for some people: “Rotating through Targets”.
At the moment, SGP can only “Rotate through events” inside a Target. But it has to finish all events before going to the next Target.
“Rotating through Targets” is a very interesting feature for lot of us:
- Panel mosaics.
- Astrometry
- Comets and asteroids
- Variable stars, etc
I don’t know anything about programming scripts, but I suppose that it should be very easy creating a Script that at the end of the sequence, it should reset the sequence and re-starts it.
In that way, if I create a sequence, for example, with 4 different targets, when all them are finished, instead of stopping the program, we can reset the entire sequence and beginning again.
It should be possible also adding a time counter (for example, re-start now or in one hour or X minutes). That it’s interesting for astrometry, as we need some time distance between new image shots. Also you need a variable counter, as you may need 1, 2 …n resets and stars.
I don’t really know if that kind of script is really easy or difficult, as I don’t know anything about programming.
What do you think? It sounds easy:
At the end of sequence:
For 1 to n
- Reset sequence
- Wait X minutes
- Re-start the sequence
Next n
Forgive me if my ignorance of programming makes me say silly things!
Fernando
