I’ve been successfully running Astrotortilla and now looking to run Astrometry.net locally via SGP. I’ve installed the local solver but it seems to be looking for the index files in a different location from AT. I’m sure there’s a way to force the local solver to look in the right directory but I can’t figure it out.
first, you’ll need a text editor that will not corrupt the Astrotortilla astrometry.net config file by converting the line endings to DOS-style. Avoid Notepad and WordPad. Notepad++ is a good free alternative, and there are numerous others.
open C:\cygwin\etc\astrometry\backend.cfg in the text editor
(I’m assuming your Astrotortilla cygwin is in the default location, C:\cygwin)
find the line that says: add_path /usr/share/astrometry/data
and add a line below it that says add_path /cygdrive/c/Users/YOUR_USERNAME/AppData/local/cygwin_ansvr/usr/share/astrometry/data
(replace YOUR_USERNAME with your Windows user name)
(the forum is splitting that into two lines, keep it as a single line in the file.)
Save the file. Make sure your editor does not convert the file to DOS-style line endings.
Run a plate solve in Astrotortilla. It should pick up the ansvr index files.
Thanks again Andy. That’s the path I was headed down and it looks like AT is properly reading the index files from the new location but I can’t get any images to solve (blind solve in seconds in SGP). These are saved images, it’s blowing 50 outside right now so no imaging. I’m not sure if I need to change any settings in AT, like the search radius? I’ve never had any luck solving saved images in AT, I’m sure I’m doing something wrong.
