I am using SGP 3.1.0.544 and having difficulty doing a auto-center after meridian flip. I use the ASTAP plate solver for its quick solving. I am not sure where to look as the logs says it failed right after solving with plate solver ASTAP and aborting immediately after it. Any insights would be helpful.
Pranab
Equipment: C11 Edge, 0.7x reducer, LiteCrawler, Canon 450D, QHY5L-III OAG
Target: M-31 4x3 mosaic section.
[12/19/20 19:05:36.508][DEBUG][Pier Flip Thread][SQ;MF;] Meridian Flip: Sending Telescope command to execute meridian flip
[12/19/20 19:05:36.517][DEBUG][Telescope Thread][SQ;MF;] ASCOM Telescope: Pier side is West
[12/19/20 19:05:36.517][DEBUG][Telescope Thread][SQ;MF;] ASCOM Telescope: attempting pier flip using slew
[12/19/20 19:05:36.520][DEBUG][Telescope Thread][SQ;MF;] Telescope: Slewing to J2000 RA: 0.759219465147074 (00h45m33.19s) Dec: 41.2257726471581 (41°13'32.78")
[12/19/20 19:05:36.520][DEBUG][Telescope Thread][SQ;MF;] Telescope: Slew received J2000 coordinates, mount requires JNOW, converting...
[12/19/20 19:05:36.521][DEBUG][Telescope Thread][SQ;MF;] Telescope: Slewing to JNOW RA: 0.778283608323637 Dec: 41.3421694606288
[12/19/20 19:06:26.924][DEBUG][Telescope Thread][SQ;MF;] Scope reports it is done with synchronous slew, verifying...
[12/19/20 19:06:26.925][DEBUG][Telescope Thread][SQ;MF;] Telescope: Slewing has completed
[12/19/20 19:06:26.925][DEBUG][Telescope Thread][SQ;MF;] Telescope: Settling for 5 seconds
[12/19/20 19:06:31.927][DEBUG][Telescope Thread][SQ;MF;] Telescope: Settling has completed
[12/19/20 19:06:32.928][DEBUG][Telescope Thread][SQ;MF;] Telescope thread is IDLE...
[12/19/20 19:06:32.950][DEBUG][Pier Flip Thread][SQ;MF;] Meridian Flip: Telescope command to meridian flip has completed
[12/19/20 19:06:32.951][DEBUG][Pier Flip Thread][SQ;MF;] Adjusting rotator for flip...
[12/19/20 19:06:32.951][DEBUG][Pier Flip Thread][SQ;MF;] Sequence is running, querying running target for target rotation info...
[12/19/20 19:06:32.951][DEBUG][Pier Flip Thread][SQ;MF;] Attempting to resolve camera angle...
[12/19/20 19:06:32.951][DEBUG][Pier Flip Thread][SQ;MF;] Syncing rotator to post flip sky angle: 91.3399963378906...
[12/19/20 19:06:32.951][DEBUG][Pier Flip Thread][SQ;MF;] Syncing the rotator to 91.34 degrees...
[12/19/20 19:06:33.086][DEBUG][Pier Flip Thread][SQ;MF;] ASCOM Rotator: Sync complete. Camera angle is 91.34; Reported pos rotator position: 214.60
[12/19/20 19:06:33.086][DEBUG][Pier Flip Thread][SQ;MF;] Camera already adjusted to 92, continuing...
[12/19/20 19:06:33.086][DEBUG][Pier Flip Thread][SQ;MF;] Meridian Flip: Telescope has performed meridian flip
[12/19/20 19:06:33.086][DEBUG][Pier Flip Thread][SQ;MF;] Meridian Flip: Flipping Auto Guider calibration data
[12/19/20 19:06:33.087][DEBUG][Pier Flip Thread][SQ;MF;] Sending to PHD2:
{"method": "flip_calibration", "id": 1005}
[12/19/20 19:06:33.161][DEBUG][PHD2 Listener Thread][SQ;MF;] Unknown object from PHD2: {"Event":"ConfigurationChange","Timestamp":1608433593.126,"Host":"TITAN","Inst":1}
[12/19/20 19:06:34.088][DEBUG][Pier Flip Thread][SQ;MF;] Autoguider (PHD2) successfully flipped calibration data
[12/19/20 19:06:34.088][DEBUG][Pier Flip Thread][SQ;MF;] Meridian Flip: Performing Auto Center
[12/19/20 19:06:34.088][DEBUG][Pier Flip Thread][SQ;MF;] Meridian flip reference data set to RA: 0.7549; Dec: 41.2161833333333
[12/19/20 19:06:34.122][DEBUG][Main Thread][SQ;MF;] BlockUntilEquipmentIdle: Start...
[12/19/20 19:06:34.122][DEBUG][Main Thread][SQ;MF;] BlockUntilEquipmentIdle: All threads are idle
[12/19/20 19:06:34.129][DEBUG][Telescope Thread][SQ;MF;] Center telescope message received...
[12/19/20 19:06:34.129][DEBUG][Telescope Thread][SQ;MF;CE;] Solving with Plate Solver ASTAP...
[12/19/20 19:06:34.194][DEBUG][Telescope Thread][SQ;MF;CE;] Auto center failed! Aborting auto center (c:1)...
[12/19/20 19:06:34.205][DEBUG][Telescope Thread][SQ;MF;CE;] Close centering dialog...
[12/19/20 19:06:34.205][DEBUG][Telescope Thread][SQ;MF;] Center telescope message completed...
[12/19/20 19:06:34.205][DEBUG][Telescope Thread][SQ;MF;] Telescope thread is IDLE...
[12/19/20 19:06:34.697][DEBUG][Main Thread][SQ;MF;] Centering dialog is closed...
[12/19/20 19:06:34.697][DEBUG][Main Thread][SQ;MF;] Adding sequence level notification: Auto center failed! Aborting auto center (c:1)...
[12/19/20 19:06:34.720][DEBUG][Main Thread][SQ;MF;] Sending Notification: Error - Auto center failed! Aborting auto center (c:1)...
[12/19/20 19:06:34.723][DEBUG][Pier Flip Thread][SQ;MF;] Recovery mode invoked but sequence is flagged as aborted, aborting recovery...
[12/19/20 19:06:43.396][DEBUG][Sequence Thread][SQ;] Blocking Pier Flip: Failed to meridian flip, aborting sequence (True)
[12/19/20 19:06:43.397][DEBUG][Sequence Thread][SQ;] Aborting sequence: Failed to meridian flip
[12/19/20 19:06:43.397][DEBUG][Sequence Thread][SQ;] Set sequence abort
[12/19/20 19:06:43.477][DEBUG][Pier Flip Thread][SQ;] Meridian Flip: Procedure complete
[12/19/20 19:06:43.477][DEBUG][Main Thread][SQ;] Adding sequence level notification: Failed to meridian flip, aborting sequence.
[12/19/20 19:06:43.511][DEBUG][Sequence Thread][SQ;] Sending Notification: Error - Failed to meridian flip, aborting sequence.
[12/19/20 19:06:43.511][DEBUG][Sequence Thread][SQ;] EventMarker(3) - t:M31-2 (5); e:0; f:8; o:* aborted *
[12/19/20 19:06:43.511][DEBUG][Sequence Thread][SQ;] EventMarker(10) - t:M31-2 (5); e:0; f:8; o:* aborted *
[12/19/20 19:06:43.511][DEBUG][Sequence Thread][SQ;] Set sequence abort
[12/19/20 19:06:43.519][DEBUG][Sequence Thread][SQ;] Run event requested sequence abort...
[12/19/20 19:06:43.521][DEBUG][Sequence Thread][SQ;] ********* Run post sequence *********
[12/19/20 19:06:43.521][DEBUG][Sequence Thread][SQ;] Resuming auto guiding...
[12/19/20 19:06:43.521][DEBUG][Sequence Thread][SQ;] EventMarker(170) - t:M31-2 (5); e:0; f:NA; o:* aborted *
[12/19/20 19:06:43.521][DEBUG][Sequence Thread][SQ;] Checking PHD2 state...
[12/19/20 19:06:43.521][DEBUG][Sequence Thread][SQ;] PHD2 GetPhdStatus - Pre-Wait : Stopped
[12/19/20 19:06:43.521][DEBUG][Sequence Thread][SQ;] Sending to PHD2:
{"method": "get_app_state", "id": 1001}
[12/19/20 19:06:43.622][DEBUG][Sequence Thread][SQ;] PHD2 GetPhdStatus - Post-Wait: Stopped
[12/19/20 19:06:43.622][DEBUG][Sequence Thread][SQ;] PHD2: Requested unpause, but PHD2 reports it is not in a paused state
[12/19/20 19:06:43.622][DEBUG][Sequence Thread][SQ;] EventMarker(171) - t:M31-2 (5); e:0; f:NA; o:* aborted *
[12/19/20 19:06:43.626][DEBUG][Sequence Thread][SQ;] SGPro capture cal frame mode is OFF...
[12/19/20 19:06:43.626][DEBUG][Sequence Thread][SQ;] Capture calibration frames on sequence failure is active. Abort status: True; User Abort: False
[12/19/20 19:06:43.626][DEBUG][Sequence Thread][SQ;] Turning capture cal frame mode OFF (because sequence was aborted by user) or no calibration frames exist.
[12/19/20 19:06:43.630][DEBUG][Sequence Thread][SQ;] Clearing timed monitoring events...
[12/19/20 19:06:43.631][DEBUG][Sequence Thread][SQ;] Checking RunEndOfSequenceEquipmentOptions, force = True
[12/19/20 19:06:43.631][DEBUG][Sequence Thread][SQ;] In RunEndOfSequenceEquipmentOptions
[12/19/20 19:06:43.631][DEBUG][Sequence Thread][SQ;] Stopping auto guiding...
[12/19/20 19:06:43.631][DEBUG][Sequence Thread][SQ;] Attempting to stop PHD2 guiding...
[12/19/20 19:06:43.631][DEBUG][Sequence Thread][SQ;] Checking PHD2 state...
[12/19/20 19:06:43.631][DEBUG][Sequence Thread][SQ;] PHD2 GetPhdStatus - Pre-Wait : Stopped
[12/19/20 19:06:43.631][DEBUG][Sequence Thread][SQ;] Sending to PHD2:
