I would like to see a auto-center sequence timer after so many frames…sort of like the Dither options. For example - after 60 frames, do an auto-center. Some folks leave their systems going for 6-7 hours, and within that time, you can have a slow drift that carries your target off-center. Please implement such a feature! Thank you.
Couldn’t you get the same result by creating several targets in a row for the same object in the sky?
I think PHD2 has a feature that can lock a star position, around which it dithers. That might work in the interim.
Well, yes you could! Sometimes the answer is right in front of you - thanks for pointing it out!
