I have been using Flats Calibration and Flats wizard for years and take a new set of flats for every session. My fixed brightness panel means fiddling around with sheets of paper to reduce brightness for broadband, whilst SII has 120s exposures.
To make things easier I have purchased an adjustable brightness panel (Giotto) but having spent all day going through documentation am still having issues.
I have sort of got Autoflats to work but I don’t feel I am using it as intended and also have some issues.
- What is the process I should be using?
For now my objective is to run autoflats manually, with a set exposure range (Say 3s to 10s), and have it work out brightness and exposure within the limits.
I have read conflicting info on either Autoflats determining the correct brightness/exposure automatically or having to first set these values up manually in Filter Flats.
So, should I be able to just run Autoflats with some constraints on exposure times and have it adjust the brightness to fit the specified exposure range?
I have managed to get it to do this to some extent but, for example, when it indicates it is using 100% (671?) brightness for Ha the panel is nowhere near full brightness and it gives an exposure of 74s. However, if I run Flats calibration and set the panel manually at 73% the exposure is only 7s.
Am I doing something wrong?
- Camera Mode. Autoflats picks up the Gain and Offset from somewhere but no details of Mode are displayed. Is it using the same Mode as specified in the camera driver? It would be reassuring to see the mode specified.
What happens if I have changed mode during imaging - e.g I am using NB and BB filters and the event uses multiple modes?
- Focuser position - does the focuser return to its original position after taking the flats?
It would be useful to have some high level documentation on how to use Autoflats - different scenarios, how to approach setting it up etc. e.g. Do you need to run Flats Calibration first to set up Filter Flats values or do you just run Autoflats. Perhaps it exists and I missed it/
Just had another thought - could autoflats be extended to also create Flat Darks for each flat. Personally, I would be happy to see this just on the Export dialogue with a tick box “Create Flat Darks” with the option to Pause between Flats and Flat Darks.
