Description
I am using SGP and a Primlucelab Sento Sento 2 focuser.
Sesto Senso 2 connects and moves manually in SGPro.
Camera connects as ASI Camera (1).
A normal 1-second Frame & Focus exposure works and downloads an image.
The Auto Focus Run button visibly clicks.
Run produces no camera exposure, no focuser movement, and no autofocus log entry.
Changing SGPro versions didn’t fix it.
A new equipment profile didn’t fix it.
SGPro accepts the mouse click on Run, but doesn’t dispatch the autofocus command. here>
Link to Logs
Useful Info
OS: ASI2600 DUO. Sento Senso 2
Ver: latest version
Ken
October 20, 2026, 4:10pm
2
Are you able to share logs showing the above? We can take a look.
jezphil
October 21, 2026, 11:52am
4
No log was created by the attempt to run the autofocus, unfortunately
Ken
October 21, 2026, 3:21pm
5
SGPro creates logs 100% of the time. Is the reporting tool showing none? You can also find them with file explorer by navigating to:
C:\Users\[your windows username]\AppData\Local\SequenceGenerator
Thank you. The log is posted on the same issue query to be found on Premium support by David Rees. We are operating the telescope together and inadvertently both posted this issue. Please refer to his post from here at Problem with Auto-Focus Sento-Senso
