Autofocus Filter change
Hello
Although autofocus is specified when changing filters, when autofocusing manually, it always switches to the L filter.
Although a filter for autofocus isn’t specified anywhere.
Maybe I’m missing something?
I can take a look at your sequence if you want to post it.
In general though:
  • the two things you specify (trigger focus on filter change and use the L filter to auto focus are not related in any way). One is a trigger and the other is a configuration honored during auto focus.
  • Using lum for focus is a pretty common configuration and can be specified in the Auto Focus settings OR in the filter settings (which is the place most people get hung up on)
Thanks, it was actually hidden in the filter setup, apparently grayed out there
