I’ve been experiencing sequence aborts in the night as a result of the focuser not quite reaching the commanded position. The relevant section of the log is below. The problem seems to start, in this case, as autofocus commands 17247 and the focuser reports 17246. What is confusing me is the references, later on, that the focuser has been commanded to 15747 ‘but’ reports 15747. Is this a mistake, or am I missing something?
My OTA is a Planewave CDK14 with EFA connected via the PWI3 interface.
Any comments welcome. I have lost several nights’ imaging due to this problem and it’s starting to drive me crazy.
[08/14/20 00:48:13.215][DEBUG][Focuser Backlash Thread][SQ;AF;BC;] Moving focuser to original requested position (17247)…
[08/14/20 00:48:13.215][DEBUG][Focuser Backlash Thread][SQ;AF;BC;] Focuser backlash compensation needed. Steps: 100 Direction:IN
[08/14/20 00:48:13.215][DEBUG][Focuser Backlash Thread][SQ;AF;BC;] Focuser moving to 17247
[08/14/20 00:48:13.215][DEBUG][Focuser Backlash Thread][SQ;AF;BC;] Focuser move call complete
[08/14/20 00:48:13.215][DEBUG][Move Monitor Thread][SQ;AF;BC;] ASCOM Focuser: Move monitor thread is started…
[08/14/20 00:48:29.663][DEBUG][Main Thread][SQ;AF;BC;] PopulateDataModel: Transferring view to the data model…
[08/14/20 00:48:29.682][DEBUG][MF Update Thread][SQ;AF;BC;] Performing serialize…
[08/14/20 00:49:57.268][DEBUG][Camera Thread][SQ;AF;BC;] ASCOM Focuser: Timeout! Focuser trying to get to 17247, reports it is at 17246. Focuser move complete reports: False
[08/14/20 00:49:57.268][DEBUG][Camera Thread][SQ;AF;BC;] MoveFocuserAbs: End, move complete, at 17246…
[08/14/20 00:49:57.268][ERROR][Camera Thread][SQ;AF;BC;] Error in auto focus! Focuser failed to move to the requested position (17247). Focuser reports it is at 17246. : Error in auto focus! Focuser failed to move to the requested position (17247). Focuser reports it is at 17246.
bei qr.a(AutoFocusData A_0, sz& A_1, sz[] A_2)
[08/14/20 00:49:57.268][DEBUG][Main Thread][SQ;AF;BC;] Adding sequence level notification: Error in auto focus! Focuser failed to move to the requested position (17247). Focuser reports it is at 17246.
[08/14/20 00:49:57.305][DEBUG][Camera Thread][SQ;AF;BC;] Sending Notification: Error - Error in auto focus! Focuser failed to move to the requested position (17247). Focuser reports it is at 17246.
[08/14/20 00:49:57.305][DEBUG][Camera Thread][SQ;AF;BC;] MoveFocuserAbs: Start, move to 15747…
[08/14/20 00:49:57.305][DEBUG][Camera Thread][SQ;AF;BC;] ASCOM Focuser: MoveSync - start…
[08/14/20 00:49:57.305][DEBUG][Camera Thread][SQ;AF;BC;] Focuser moving to 15747
[08/14/20 00:49:57.306][DEBUG][Camera Thread][SQ;AF;BC;] Focuser move call complete
[08/14/20 00:49:57.306][DEBUG][Move Monitor Thread][SQ;AF;BC;] ASCOM Focuser: Move monitor thread is started…
[08/14/20 00:51:57.374][DEBUG][Camera Thread][SQ;AF;BC;] ASCOM Focuser: Timeout! Focuser trying to get to 15747, reports it is at 15747. Focuser move complete reports: False
[08/14/20 00:51:57.374][DEBUG][Camera Thread][SQ;AF;BC;] MoveFocuserAbs: End, move complete, at 15747…
[08/14/20 00:51:57.374][DEBUG][Camera Thread][SQ;AF;BC;] Auto focus (finally): closing dialog…
[08/14/20 00:52:08.282][DEBUG][Camera Thread][SQ;AF;BC;] Auto focus complete…
[08/14/20 00:52:08.290][DEBUG][Camera Thread][SQ;BC;] SGM_FOCUSER_AUTO_FOCUS complete…
[08/14/20 00:52:08.290][DEBUG][Camera Thread][SQ;BC;] Camera thread is IDLE…
[08/14/20 00:53:08.363][DEBUG][Sequence Thread][SQ;BC;] BlockUntilFocuserMovementDone: Timeout! Focuser trying to get to 15747, but reports it is at 15747!
[08/14/20 00:53:08.363][ERROR][Sequence Thread][SQ;BC;] Focuser movement timeout detected…
[08/14/20 00:53:08.363][DEBUG][Sequence Thread][SQ;BC;] EventMarker(4) - t:NGC6992-3 (1); e:0; f:2; o:
[08/14/20 00:53:08.363][DEBUG][Sequence Thread][SQ;BC;] Setting filter position 6…
[08/14/20 00:53:08.363][DEBUG][Sequence Thread][SQ;BC;] Filter position 6 is already set. Skipping…
[08/14/20 00:53:08.363][DEBUG][Sequence Thread][SQ;BC;] EventMarker(5) - t:NGC6992-3 (1); e:0; f:2; o:
[08/14/20 00:53:08.363][DEBUG][Sequence Thread][SQ;BC;] Checking for auto manual focus (pre)…
[08/14/20 00:53:08.363][DEBUG][Sequence Thread][SQ;BC;] EventMarker(6) - t:NGC6992-3 (1); e:0; f:2; o:
[08/14/20 00:53:08.363][DEBUG][Sequence Thread][SQ;BC;] Running dither…
[08/14/20 00:53:08.380][DEBUG][Sequence Thread][SQ;BC;] mm - DM dither request sent: 500ms…
[08/14/20 00:53:08.600][DEBUG][Sequence Thread][SQ;BC;] mm - Pulse is async. Settle will be faked for 500ms
[08/14/20 00:53:08.603][DEBUG][Sequence Thread][SQ;BC;] EventMarker(7) - t:NGC6992-3 (1); e:0; f:2; o:
[08/14/20 00:53:08.603][DEBUG][Sequence Thread][SQ;BC;] Resuming auto guiding…
[08/14/20 00:53:08.603][DEBUG][Sequence Thread][SQ;BC;] EventMarker(170) - t:NGC6992-3 (1); e:0; f:2; o:
[08/14/20 00:53:08.603][DEBUG][Sequence Thread][SQ;BC;] EventMarker(171) - t:NGC6992-3 (1); e:0; f:2; o:
[08/14/20 00:53:08.603][DEBUG][Sequence Thread][SQ;BC;] EventMarker(172) - t:NGC6992-3 (1); e:0; f:2; o:
[08/14/20 00:53:08.603][DEBUG][Sequence Thread][SQ;BC;] Checking status of auto guider start…
[08/14/20 00:53:08.603][DEBUG][Sequence Thread][SQ;BC;] EventMarker(173) - t:NGC6992-3 (1); e:0; f:2; o:
[08/14/20 00:53:08.603][DEBUG][Sequence Thread][SQ;BC;] User has elected to skip guider settling over time…
[08/14/20 00:53:08.656][DEBUG][Sequence Thread][SQ;BC;] Waiting for Auto Guider distance to fall below 0,5
[08/14/20 00:53:08.662][DEBUG][Sequence Thread][SQ;BC;] Distance is below 0,5, starting timer…
[08/14/20 00:53:09.170][DEBUG][Sequence Thread][SQ;BC;] Distance stayed below 0,5 for 0 seconds, done settling…
[08/14/20 00:53:09.171][DEBUG][Sequence Thread][SQ;BC;] Auto guider has settled…
[08/14/20 00:53:09.297][DEBUG][Sequence Thread][SQ;BC;] EventMarker(8) - t:NGC6992-3 (1); e:0; f:2; o:
[08/14/20 00:54:09.364][DEBUG][Sequence Thread][SQ;BC;] BlockUntilFocuserMovementDone: Timeout! Focuser trying to get to 15747, but reports it is at 15747!
[08/14/20 00:54:09.364][DEBUG][Sequence Thread][SQ;BC;] Capture event timeout…
[08/14/20 00:54:09.364][DEBUG][Sequence Thread][SQ;BC;] Run event reported timeout…
[08/14/20 00:54:09.364][DEBUG][Main Thread][SQ;BC;] Adding sequence level notification: Timeout! Sequence has been aborted.
[08/14/20 00:54:09.394][DEBUG][Sequence Thread][SQ;BC;] Sending Notification: Error - Timeout! Sequence has been aborted.
